mariusoroian
probleme cu martor de bord (sist. de control al emisilor)
24 Iul 2010, 14:06
001089 evap emission control sys incorect flow
p0441-002-lower limt exceeded intermitent
mi sa spus ca benzina nu e buna si trb sa fol. cu cifra oct. 98/100
am un seat leon cupra 2008
Marius
Re: probleme cu martor de bord (sist. de control al emisilor)
24 Iul 2010, 23:21
Evaporative Emission (EVAP) Canister Purge Regulator Valve (N80) faulty/jammed
* Evaporative Emission (EVAP) Canister Purge Solenoid Valve (N115) faulty/jammed
* Evaporative Emission (EVAP) Canister Sealing faulty
* Pipes between Tank Breathing and Throttle Body leaky/blocked
