  • 14
  • 15
  • 16
  • 17
  • 18
  • 166
Re: Leon 1M 2006 - FR KIT
17 Mai 2011, 22:20
Cu sfaturi, te ajut oricand. Piese nu am :tongue
23 Mai 2011, 14:19
O poza de familie: stanga leonul lui cty, mijloc leonul lui liviu12s.
23 Mai 2011, 15:17
Si masina ta arata beton.Dupa cate vad te-ai dedicat trup si suflet acestei marci de masina inseamna ca ti mult la ea.Masina arata impecabil,sa ai grija de ea si pe viitor la fel ca si acum,si la cati mai multi KM. :hi
LEON 1.4 16V Kit FR
chelie77
Localitate: BUCURESTI-Bd 1 Decembrie
23 Mai 2011, 20:15
Frumoase Leoanilii :drive
Seat Ibiza 1.9 SDI 2002
viewtopic.php?t=2374
24 Mai 2011, 07:21
chelie77 scrie:
:hi :hi
O sa ma joc un pic cu climatronicul, sa vad ce e cu aceste coduri:
hanging Degree Temperature Display
Press and hold the recirculation button. Then press the temperature up ("+") button to switch between degrees Celsius & Fahrenheit on the Climate Control Temperature and Instrument Panel Outside Temperature displays.
Accessing On-Board Diagnostic codes
Press and hold the recirculation button. Then press the manual flow control up arrow. You should see a 1c. Press the temperature up ("+") or down ("-") buttons to select a code number. Then press the recirculation button again. The value should display. Press the temperature up or down button again to display another code.
NOTE: Air Flow Motor (V 71) and Potentiometer (G 113) are not installed in USA/Canada vehicles. Disregard values displayed for these components.
Code Displayed Value
1 System malfunction - displayed as a Diagnostic Trouble Code (DTC), see chart below
2 Digital value of Interior Temperature Sensor, in Headliner (G 86)
3 Digital value of Interior Temperature Sensor, in Instrument Panel (G 56)
4 Digital value of Fresh Air Intake Duct Temperature Sensor (G 89)
5 Digital value of Outside Air (Ambient) Temperature Sensor (G 17), front
6 Digital value of Outside Air (Ambient) Temperature Sensor
7 Digital value of Ambient Temperature Sensor At Fresh Air Blower (G 109)
8 Digital value of Temperature Regulator Flap Motor Potentiometer (G 92)
9 Delta value of Temperature Regulator Flap
10 Non-corrected specified value of Temperature Regulator Flap
11 Digital value of Central Flap Motor Potentiometer (G 112)
12 Specified value of Central Flap
13 Digital value of Footwell/Defroster Flap Motor Potentiometer (G 114)
14 Specified value of Footwell/Defroster Flap
15 Digital value of Air Flow Flap Motor Potentiometer (G 113)
16 Specified value of Air Flow Flap
17 Vehicle Speed (km/h)
18 Actual Air Blower voltage (Volts)
19 Specified Fresh Air Blower voltage (Volts)
20 A/C Compressor (A/C Clutch) voltage (Volts)
21 Number of low voltage occurrences, non-transient
22 Cycle condition of A/C Refrigerant High Pressure Switch (F 118)
23 Cyclings of the A/C Refrigerant High Pressure Switch (F 118)
24 Cyclings of the switches, absolute non-fluctuating
25 Analog/Digital value, Kick-Down Switch
26 Analog/Digital value, Engine Coolant Temperature (ECT) Warning Light
27 Engine Speed (RPM)
28 N/A
29 A/C Compressor speed in rpm (Equals Engine Speed x 1.28)
30 Software version
31 N/A
32 Potentiometer malfunction counter, Temperature Regulator Flap
33 Potentiometer malfunction counter, Central Flap
34 Potentiometer malfunction counter, Footwell/Defroster Flap
35 Potentiometer malfunction counter, Air Flow Map
36 Feedback value, cold end-stop, Temperature Regulator Flap Motor Potentiometer (G 92)
37 Feedback value, hot end-stop, Temperature Regulator Flap Motor Potentiometer (G 92), max. stop
38 Feedback value, cold end-stop, Central Flap Motor Potentiometer (G 112)
39 Feedback value, hot end-stop, Central Flap Motor Potentiometer (G 112)
40 Feedback value, cold end-stop, Footwell/Defroster Flap Motor Potentiometer (G114)
41 Feedback value, hot end-stop, Footwell/Defroster Flap Motor Potentiometer (G114)
42 Feedback value, cold end-stop, Air Flow Map Motor Potentiometer (G 113)
43 Feedback value, hot end-stop, Air Flow Map Motor Potentiometer (G 113)
44 Vehicle operation cycle counter
45 Calculated interior temperature (internal software, in digits)
46 Outside (ambient) temperature, filtered, for regulation (internal software)
47 Outside (ambient) temperature, unfiltered, (internal software, in deg C)
48 Outside (ambient) temperature, unfiltered, (in digits)
49 Malfunction counter for speedometer (vehicle speed) signal
50 Standing time (in minutes)
51 Engine Coolant Temperature (ECT) in deg C
52 Graphics channel 1 - A/C compressor switch-off conditions are identified by illuminated segments of the “88.8” display. See chart below.
53 Graphics channel 2 - Climate system electrical outputs are identified by illuminated segments of the “88.8” display. See chart below.
54 Control characteristics
55 Outside (ambient) temperature, in deg C or deg F depending on setting on A/C control head
56 Temperature in deg C, from Interior Temperature Sensor, in Headliner (G 86)
57 Temperature in deg C, from Interior Temperature Sensor, in Instrument Panel (G 56)
58 Temperature in deg C, from Fresh Air Intake Duct Temperature Sensor (G 89)
59 Temperature in deg C, from Outside Air (Ambient) Temperature Sensor (G 17), front
60 Temperature in deg C, from Ambient Temperature Sensor At Fresh Air Blower (G 109)
61 Software version (latest)
86 Display Check (All Segments of Climate Control display light up
26 Mai 2011, 06:40
Sa pun si aici pozele de la liviu12s (multumesc) :hi
puputavi
Localitate: Cluj
26 Mai 2011, 16:31
Lipseste una gri dintre ele :P
Frumoase!
3.0 TDI Quattro S-tronic
26 Mai 2011, 17:02
Oh da, gri, gri, dar cu ce motor :yah
Mi-ar placea sa facem o intalnire DOAR cu 1M :cheers
mcbeowolf007
26 Mai 2011, 20:55
Accepatati si una albastra?:)
Nissan Cherry 1.3DX || Opel astra hatch'93
Golf III 1.9TD
Seat Toledo 1.9 Tdi ||Audi A4 1.9 PD 2002
Seat Leon Top Sport 1.9 TDI IS-25-WEEEEE
http://www.clubseat.eu/viewtopic.php?f=5&t=2346
26 Mai 2011, 22:54
Normal :cheers . Iar la asa nuanta albastra, va fi un adevarat deliciu :cheers :cheers
28 Mai 2011, 07:10
Ieri am fost intr-o scurta vizita la service Alto, pentru a verifica daca am suficient freon si am vazut ca aveau o promotie "verificare de primavara"- 34 RON, asa ca am profitat si eu. Prin urmare:
- test VAS - ok
- lumini, becuri, etc- ok
- verificare rampa: - amortizoare spate scurse, amortizoare fata ok, bucsi bascula posterioare imbatranite - recomandare pentru schimbat; alte articulatii ok, fara jocuri.
- buson/capac ulei de la motor - trebuie inlocuit, nu mai etanseaza bine
- test frane: perfect
- test amortizoare: 65% fata, 50% spate
- verificat AC - ok (6 grade la gurile de ventilatie)
28 Mai 2011, 14:53
In general stai bine. Noroc de setul nou de suspensie care urmeaza.
28 Mai 2011, 22:30
Da, dupa 5 ani, stam bine. Daca ma uit un pic in urma si trag linie nu au fost probleme pana acum.
Am schimbat una bucata parbriz dupa ce s-au adunat 3 "flori"in 6 luni, iar ultima o luase la plimbare pe partea soferului (asta s-a intamplat prin 2007 - schimbat pe CASCO). Una bucata coloana de directie schimbata in garantie, tot in 2007. Una bucata baterie schimbata asta iarna si multe consumabile: becuri H7, stergatoare, placute frana, filtre, discuri frana...etc. In rest, motor ok, cutie ok, ambreiaj ok, EGR + turbina ok si fara accidente :cheers
puputavi
Localitate: Cluj
29 Mai 2011, 11:46
Eu dupa 8 ani sunt inca tot cu bateria originala. A dat putine urme de oboseala iarna trecuta dar vad ca se tine inca...
29 Mai 2011, 11:50
Da, si eu sunt cam dezamagit ca a cedat asa devreme. Macar sa fi rezistat 5 ani in cap, in loc de 4 ani jumate.
  • 14
  • 15
  • 16
  • 17
  • 18
  • 166
