Re: Leon 1M 2006 - FR KIT
25 Iul 2016, 16:39
Am vorbit acum la alto syncro si se pare ca acel furtun se da la dm si are codul 1J0955751D. Apare si in ETKA, sub poz 10.
mihai.b
25 Iul 2016, 16:59
Si eu am cautat codul in ETKA si pe google in toate felurile dar nu l-am gasit. Cred ca la furtun te referi
Sent from my SM-G388F using Tapatalk
25 Iul 2016, 18:00
Furtun, furtun, am editat :)
28 Iul 2016, 10:28
Nu cred ca am postat pana acum VIN decoder-ul de la belgian, asa ca voila:
Cod vanzare: 1M13V4
An model: 2006
Denumire model: Leon Stella
Cod motor: AXR
Cod cutie viteze: EUH
Tip transmisie: 5S
Dotare: BP
Culoare plafon: Z4
Culoare exterioara/Cod vopsea: Z4/C9Z
Data fabricatie:30.03.2006
A8D Luxury equipment
AZ0 Vehicle with standard production scope
B02 Type approval Belgium
B0C Component parts set, complying with vehicle type for Belgium, various parts
C2S Cast alloy wheels 6J x 15 offset 38 (1C0 601 025 F)
C30 Operating permit, alteration
E82 "Sporty Entry"
F0A No special purpose vehicle, standard equipment
G0C 5-speed manual transmission
G25 Front shock absorption
H7F Tires 195/65 R15 91H
J0L Battery 340 A (70 Ah)
K8G Hatchback
L06 Suspension range 06 installation control only, no requirement forecast
L0L Left-hand drive vehicle
MS7 4-cyl. turbo diesel eng. 1.9 L/74 kW TDI pump-jet injection system
Base engine is T5X/T21/T71
N2C Fabric seat covering
PE4 Electric equipment package (windows +mirrors + foldable outer rearview mirrors)
PH2 "Climatronic"
Q4H Comfort sports seats, front
QA0 Without child seat
QG2 No possibility of activating service interval prolongation
QS0 Without electronic map cooling system
T5X 4-cylinder diesel engine 1.9 L unit 038.L
U0C Instrument insert with tachometer clock and km/h speedometer
UB5 Rear shock absorption for sports design
V0A Tires w/o specification of tire brand
0A2 4 doors
0AE Front stabilizer
0BC Rear stabilizer
0CK Vehicle class differentiation 1M0
0EJ Installation differentiation for transmission MQ 250 vehicle components
0F9 Cooled fuel system for diesel engine
0FA Standard manufacturing sequence
0G4 Cable gearshift
0GG Emission standard EU4
0KA Without stickers and badges
0L2 Electric throttle actuation
0N5 Standard rear axle
0RA Without ignition/starter switch locking system
0SG Labels/plates in French
0TA Without floor mats
0UA Without special color trim
0XN Information kit in French and Dutch
0YZ Without determination of weight category for rear axle
1AC Anti-lock brake system (ABS)
1C1 Antifreeze up to -25 degree celsius tolerance up to -30 degree C
1D3 Vorbereitung mit verstärkter Kühlung
1E0 Without activated charcoal canister
1EX Spezielles Typschild für EG
1G2 Steel spare wheel with original equipment tires
1H0 Without proportioning valve
1KK Disc brakes, rear
1LS Front disc brakes with integrated adapter
1N6 Power steering
1NL Covers for alloy wheels
1PA Standard wheel bolts
1Q0 Without mass damper for steering wheel
1S1 Tool kit and jack
1SA Without additional front underbody guard
1T0 Without first aid kit and warning triangle
1X0 Front wheel drive
1Z0 Initial standard fuel filling
2B3 Additional exterior noise suppression
(hood, capsule and dash panel)
2C5 Axial and vertical adjustable steering column
2D1 Complete cd enhancing underbody panel
2G8 Filler neck module 2 without insert
2JS Body-colored bumpers with protective moldings
2LB Fuel tank with special material treatment
2PX Leather trimmed sports steering wheel
2UA Standard design
2V0 Fresh air intake without air cleaner
2VP Nameplate set "TDI" "I"
2W0 Fuel filler cap
2WA Without additional tires
3B0 Without additional child seat anchor
3C7 3-point seat belt for center rear seat
3CA Without partition
3FA Without roof insert (standard roof)
3GA Without cargo area
3H0 Without backrest release for front seats
3J7 Articulated and height-adjustable headrests for front seats
3L3 Manual height adjustment for front seats
3M0 Without special measures
3NC Rear seat bench/backrest, split folding
3P1 Bracket for first aid kit and warning triangle
3Q1 Rear headrests
3S0 Without roof rails/roof load rack
3U1 Foldable trunk cover
3Y0 Without roll-up sun screen
3YQ Door pockets without insert mats
3ZM 3-point seat belts, outer rear
4A0 Without seat heater
4AF Door and side trim panel in foam film and woven fabric
4B1 Protective side molding
4E0 Tailgate/trunk lid unlocking from outside
4GF Windshield in heat-insulating glass
4J5 Floor tray, extension center console
4K3 Radio remote controlled central locking
operated from inside and safe securing
4KC Side and rear windows in heat-insulating glass
4L2 Dipping breakaway interior rear view mirror
4LA Without controls
4M5 Cup holder
4N1 Padded dashboard
4P0 Rear floor panel module, type 1
4Q1 Flame retardent materials
4QU 3-point seat belts front w/ tensioner (electr.) and height adjustment
4R4 Power windows with comfort operation and circuit breaker
4SC Left vanity mirror with cover
4TC Right vanity mirror with cover
4U3 Luggage net on backrest, right seat
4UF Driver's and front passenger air bag
with front passenger air bag deactivation
4W0 Without cassette and CD storage unit
4X1 Side air bag front
4XF Exterior pillar lining design 2
5A2 Comfort trunk lining
5C0 Without special body measures
5D1 Carrier frequency 433.92 MHz-434.42 Mhz
5J5 Body-colored rear spoiler (version 2)
5K1 Paint preservative (wax)
5N2 Folding grab handles at roof frame
5RQ Right exterior mirror: convex
5SL Left exterior mirror: aspherical
6A0 Without fire extinguisher
6E0 Without center armrest front
6EA Without additional side body covers (stone guard)
6FB Body-colored exterior mirror housings
6KA Radiator grille
6NA Unsplit molding roof liner
6P0 Without license plate bracket rear
6PA Plastic hand brake lever handle
6Q9 Leather gearshift knob/handle
6QA Rear seat catch
6R2 Leather gearshift boot
6SC Tufted trunk floor covering
6W0 Without license plate bracket front
6XE Exterior mirrors: electrically foldable and electrically adjustable/heated
6Y0 Without cruise control warning system
7A0 Without CD changer/CD player
7AA Electronic vehicle immobilization device
7B0 Without socket
7E0 W/o heat accumulator/auxiliary heating
7P0 Without lumbar support in seat backrests
7PB Platform group class 2
7Q0 Without navigation device
7QA Without CD/DVD for navigation
7R3 Side turn signal lights (white)
7TH Dekor-Einlagen, Quecksilber
7X0 Without park distance control
8BB Halogen headlight for driving on the right
8CC Speedometer sensor without seal
(electronic speedometer sensor)
8E2 Local interference suppression for FM/AM radio reception
8GD Alternator 90A
8K0 Without special headlight activation
8KA W/o catalytic converter warning light
8L3 Roof antenna
8M1 Rear window wiper and washer system
with intermittent control
8MA Without headphone port rear
8N4 Windshield wiper intermittent control
with potentiometer (four speeds)
8P1 Heated rear window
8Q1 Headlight-range adjustment
8QE Key for locking system with remote control
8RL 6 speakers (passive)
8S2 One reading light front, two reading lights rear
8SA Taillight assemblies, standard design
8T0 Without cruise control system (CCS)
8TF Rear fog lights, left and right
8UE Radio with CD drive
8W1 Washer fluid level indicator
8WD Integrated front fog light
8X0 Without headlight washer system
8Y0 Single-tone horn
8Z5 Not hot country
9A0 Without taxi alarm system
9AK Climatronic with impact pressure control free of cfc
9D0 Without preparation for two-way radio installation
9FA Without automatic transmission indicator light
9GA Interior light with door pillar switches
9J0 Without supertone system and tone sequence control
9JB Smoking package, ashtray front and rear
9M0 Without auxiliary/parking heater
9P0 Without seat belt reminder
9Q1 Multi-function display/on-board computer
9T0 Without heated washer nozzles
9TC Additional reflectors (door area)
9U0 Without brake pad wear indicator
9W0 W/o car phone preparation/installation
9X0 Without heated door lock cylinder
9Y1 Outdoor temperature gage
01 Aug 2016, 19:09
Azi am fost cu ea la RAR, am stat vreo 2 ore jumate si totul a fost ok. In CIV au trecut doar 2 dimensiuni de anvelope: 195/65/15 si 205/50/17 care sunt pe masina. Urmeaza traduceri acte, mers la fianciar, apoi anaf si politie. Sper sa am timp sa le fac zilele astea.
I-am schimbat si furtunul de la stropitori :)
01 Aug 2016, 19:11
Spor la alergat si rabdare maxima,pentru ca ai nevoie la cata birocratie tampita exista inca in tara asta.
Apropo...,cand o vopsesti?
EX: LEON 1.4 16V Kit FR
01 Aug 2016, 19:28
Habar nu am....poate la anul, nu stiu, sa se mai adune :)
andimiroiu
Andrei
01 Aug 2016, 20:51
si eu tot 2 anvelope am in CIV de 205 si de 225.
cat te duce taxa la anaf ?
01 Aug 2016, 21:52
Trebuie sa ajung la ei sa-mi spuna exact. Conform calculatorului de pe site-ul lor, taxa este de 422 Euro: vechime 10-11 ani, emisii 138g si Euro 4.
02 Aug 2016, 19:15
Azi am rezolvat cu finaciaru'. E deranj mare, multa altergatura si timp pierdut.
Intre timp poze cu fratele olandez si zeusik ;)
Imagine.Imagine.Imagine.Imagine.Imagine
zeusik
Nashul
02 Aug 2016, 19:21
:cheers
03 Aug 2016, 20:00
Azi am fost si la ANAF ca sa depun actele pt taxa de timbru. In timp ce eram la coada, un nene mi-a spus ca e bine sa mai astept si sa nu platesc taxa pt ca se va scoate definitiv la 1 septembrie.
Imi poate confirma cineva treaba asta?!
03 Aug 2016, 21:02
Din cate stiu eu,si taxa actuala este declarata ilegala,dar din cate am auzit,de la 1 septembrie se schimba taxa ca sa fie mai "rezonabila",nu se elimina...,asteptam si alte pareri poate sunt unii care stiu mai multe detalii.
Ciosmi
03 Aug 2016, 21:15
Nu cred ca se scoate. In schimb, am auzit ca se miscoreaza.
Personal astept luna septembrie pentru a lua o decizie in privinta inmatricularii. Iti recomand acelasi lucru.
09 Aug 2016, 17:13
Din pacate nu mai pot astepta pana atunci. O voi inmatricula in conditiile actuale. Multumesc pentru postari :)
Intre timp facem km prin tara si am gasit si o parte din codul de la furtunasul dintre duzele pentru spalat parbrizul, insa nu ma ajuta la nimic: 1M0 955 96...
Am inlocuit si litera ''D" de pe haion cu una rosie primita donatie de la florineatza. Multumesc inca o data :)
