buzzy
Localitate: lucca italia
raport distributie tractiune la seat leon tdi cupra 4
21 Aug 2009, 23:23
salut!....am un leon cupra 4 tdi din 2002 si as vrea sa aflu si eu raportul de distributie a tractiunii fata/spate in mod normal :?: !mc anticipat!
seat leon cupra 4---tdi 180cp
Re: raport distributie tractiune la seat leon tdi cupra 4
22 Aug 2009, 01:00
Fii te rog mai explicit, cum adica "raportul de distributie a tractiunii fata/spate in mod normal"
:shock:
buzzy
22 Aug 2009, 01:31
ma refeream.............in mod normal care este raportul de tractiune al masinii....................dar am gasit, in mod normal are tractiune fata iar cand se pierde stabilitatea tractiunea este 50 50.
Haldex: open front diff with EDL, electronically controlled Haldex clutch center, open rear diff with EDL.
Part-time automatically engaging four-wheel drive.
Is on: all VAG cars with transversely mounted engines, so Audi A3 quattro, S3, TT quattro, VW Golf/Bora 4motion, Seat Leon 4, Skoda Octavia 4x4. Normally FWD but Haldex directs torque to the rear when slip occurs to a maximum torque split of 50/50. Is also the system of use in the latest Volvo AWD models (S60, V70, XC70).
Differentials/clutches
Open diffs are the most common type of diff. Wheels (or axles on a 4x4) can turn freely relative to each other. They have no means of balancing power delivery if one wheel has less traction than the other.
Limited-slip diffs (or LSDs) allow the two wheels to turn relative to each other, but limits the rate at which they are allowed to do so (usually either by some sort of friction or fluid coupling). This ensures that, even if one wheel loses traction, some power is still delivered to the other.
Lockable diffs (not to be confused with EDL) physically lock the two half-axles together. This is fine for off-road travel, but can cause problems when trying to turn on high-grip surfaces - one wheel gets \"dragged\" around.
The electronic differential lock (EDL) employed by VAG is not - as the name suggests - a differential lock at all. Sensors monitor wheel speeds, and if one is rotating substantially faster than the other (i.e. slipping) the EDL system momentarily brakes it. This effectively transfers all the power to the other wheel.
buzzy
22 Aug 2009, 01:40
mie uneori imi da eroare la abs si stabilitate...........din cauza senzorului abs si esp, care se afla pe rulment la roata si nu mai citeste bine uneori.................intrebarea mea ar fi:...... poate acest senzor sa aiba vreun efect asupra sistemului de tractiune integrala, dak parcurg distante mari cu eroarea aprinsa pe bord, din moment ce sistemul halden il citeste k pe o pierdere a stabilitatii si presupun k activeaza 4x4? :roll:
mike20
22 Aug 2009, 15:14
la haldex din cate stiu eu este 90%fata si 10% spate si trece la nevoie sau in cazul unei plecari bruste pana la 50-50
Seat Leon 1P Sport-Up 2.0TDI 140cp
buzzy
22 Aug 2009, 20:01
Zipp3r
23 Sep 2009, 23:24
Stie careva daca o cupra R din 2004-2005 are tractiune 4X4?
Leon 2004 - Cupra R 1.8 - 224cp
Ciosmi
16 Oct 2009, 00:21
Nu s-a pus 4x4 pe .:R
buzzy
20 Noi 2009, 22:27
problema rezolvata!dadea eroare din cauza senzorului longitudinal de acceleratie!o luase razna, dar l-am skimbat si acum totul este ok!
sir_edi
Localitate: iasi
18 Mar 2010, 17:21
zipp3r leon-ul tau e cupra r fabrica?
Seat Leon 2002 1.9 tdi
