GtSport
Re: Noul Leon Cupra R
16 Ian 2010, 19:50
Am gasit aceste informsaatii pana acum:
Se pare ca nu este intercoolerul de pe Cupra dar pare a nu fi nici cel de s3:
Cupra R are codul de motor CDLA
In concluzie - Codurile motor:
2007-2009 Cupra - BWJ
2010 Cupra - CDLD
2010 Cupra R - CDLA
Componente:
Turbo
BWJ - 06F 145 702C
CDLD - 06F 145 702C
CDLA - 06F 145 702C
Intercooler
BWJ - 1K0 145 803 S
CDLD - 1K0 145 803 S
CDLA - 1K0 145 803 AK
Fuel Pump (Interesting one, but possibly subject to update on ETKA)
BWJ - 06F 127 025J
CDLD - 06F 127 025J
CDLA - 06F 127 025J
Be aware that the BWA also uses this same fuel pump. Also note that this part could be direct replacement for all previous fuel pumps to contain uprated internal parts, but still using the old part number.
Intake Camshaft
BWJ - 06F 109 101 G
CDLD - 06F 109 101 H
CDLA - 06F 109 101 H
Exhaust Camshaft
BWJ - 06F 109 102D
CDLD - 06F 109 102D
CDLA - 06F 109 102D
Injectors
BWJ - 06F 906 036F
CDLD - 06F 906 036F
CDLA - 06F 906 036F
Gearbox
BWJ - Code KDU (07-08) and KPA (08-09) - 02Q 300 042D - Gearing 72.17.22
CDLD - Code KZW - 02Q 300 045J - Gearing 70.17.22
CDLA - Code LMN - 02Q 300 046J - Gearing 72.17.22
Flywheel
BWJ - 06F 105 266M
CDLD - 06F 105 266M
CDLA - 06F 105 266M
Clutch (Clutch plate and Pressure Plate)
BWA - 022 141 015R
BWJ - 022 141 015R
CDLD - 022 141 015R
CDLA - 022 141 015R
Air Intake 3 Piece
BWA - 1K0 805 971C Feeds in to 1K0 805 962C Lid is 1K0 805 965C - Oval Trumpet - 1K0129 618AH
BWJ - 1K0 805 971C Feeds in to 1K0 805 962C Lid is 1K0 805 965C - Oval Trumpet - 1K0129 618AH
CDLD - 1K0 805 971C Feeds in to 1K0 805 962C Lid is 1K0 805 965C - Oval Trumpet - 1K0129 618AH
CDLA - 1K0 805 971C Feeds in to 1K0 805 962C Lid is 1K0 805 965C - Oval Trumpet - 1K0129 618AH
Air Filter Assembly (Engine Cover)
BWA - 06F 133 837AA (TFSi)
BWJ - 06F 133 837AD (CUPRA)
CDLD - 06F 133 837AL (CUPRA)
CDLA - 06F 133 837AN (CUPRA R)
Cat Back Exhaust
BWJ - 1P0 253 181H
CDLD - 1P0 253 181H
CDLA - 1P0 253 181M
Downpipe/Catalyst
BWJ - 1K0 254 508B up to 07 - 1K0254 507L 07 on
CDLD - 1K0 254 512L
CDLA - TBC
Imi pare rau, nu am stat sa traduc tot dar cred ca se intelege.
LE: Se pare ca 1K0 145 803 AK este part number-ul intercoolerului de S3 actualizat.
Utilizatori ce ce navighează pe acest forum: bgd_b92 și 2 vizitatori
