popa.andreialex
probleme unitate control comenzi volan si eroare airbag
15 Mai 2016, 12:47
Salut. Ma poate ajuta si pe mine cineva cu niste informatii? Am o problema cu comenzile de pe volan. Nu functioneaza nici claxonul nici butoanele. I-am facut un scan cu vag comul si am urmatoarele erori. Intrebarea este: daca inlocuiesc unitatea de control de pecoloana de directie si inelul acela din spate de la volan, vor disparea si eroarea de la airbag, steering angle si instrumente? Am desfacut zilele trecute coloana si carcasa de la folia din spatele volanului e rupta. Later edit: daca este cineva din Cluj si are nevoie: mi-am cumparat o mufa de scanner :))
Friday,13,May,2016,15:50:16:62939
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: Release 12.12.0 (x64)
Data version: 20130910
VIN: VSSZZZ1PZ8R039966 License Plate:
Chassis Type: 1P (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
VIN: VSSZZZ1PZ8R039966 Mileage: 168360km/104614miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine Labels: 03G-906-021-BLS.clb
Part No SW: 03G 906 021 PA HW: 03G 906 021 AB
Component: R4 1,9L EDC G000SG 1329
Revision: --H07--- Serial number: SEZ7Z0G3869386
Coding: 0050071
Shop #: WSC 80093 222 69422
VCID: 6DD12F3F746425764F5-8038
1 Fault Found:
005488 - Engine Start Blocked by Immobilizer
P1570 - 000 - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 1
Fault Frequency: 2
Reset counter: 255
Mileage: 166481 km
Time Indication: 0
Date: 2000.00.00
Time: 22:14:15
Freeze Frame:
RPM: 1029 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.48 V
Bin. Bits: 00001100
Bin. Bits: 00000000
(no units): 33.0
Readiness: 0 0 0 0 0
Address 03: ABS Brakes Labels: 1K0-907-379-MK70.lbl
Part No: 1K0 907 379 P
Component: ASR FRONT MK70 0105
Coding: 0017025
Shop #: WSC 04941 785 00200
VCID: 3F8DA5776E8867E6AD9-806A
No fault code found.
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No: 1P0 907 044 B
Component: ClimatronicPQ35 011 0602
Shop #: WSC 00000 000 00000
VCID: 2B55E1278AF0EB46111-807E
Address 09: Cent. Elect. Labels: 3C0-937-049-30-H.lbl
Part No SW: 3C0 937 049 AJ HW: 3C0 937 049 AJ
Component: Bordnetz-SG H54 2202
Revision: 00H54000 Serial number: 00000005114451
Coding: 99880F2F000410FFC31D00000000000000117F075C400000000000000000
Shop #: WSC 12345 123 123456
VCID: 71E9334F685CC1966BD-8024
Subsystem 1 - Part No: 1P0 955 119 B Labels: 1KX-955-119.CLB
Component: Wischer 190907 022 0601
Coding: 00056208
Shop #: WSC 12345
Address 15: Airbags Labels: 3C0-909-605.lbl
Part No SW: 3C0 909 605 L HW: 3C0 909 605 L
Component: R3 AIRBAG VW8 030 2522
Revision: 12030000 Serial number: 003B0PJPB4DP
Coding: 0021043
VCID: 2F6DF537BEE897663D9-807A
Subsystem 1 - Serial number: 6332MSME2F217250
Subsystem 2 - Serial number: 6342MSME2F224603
Subsystem 3 - Serial number: 6351HTS61CG4D967
Subsystem 4 - Serial number: 6361HTS61CGGTQT6
Subsystem 5 - Serial number: 00000000000000000
Subsystem 6 - Serial number: 00000000000000000
1 Fault Found:
00588 - Airbag Igniter; Driver Side (N95)
001 - Upper Limit Exceeded - MIL ON
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 AQ HW: 1K0 953 549 AQ
Component: J0527 636 0070
Coding: 0002042
VCID: 8109E38FD8FC51161BD-80D4
1 Fault Found:
01426 - Controls in Steering Wheel (E221)
004 - No Signal/Communication
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No: 1P0 920 823 G
Component: KOMBIINSTRUMENT VO3 0424
Coding: 0000101
Shop #: WSC 10101 599 45725
VCID: 306FF64BA3D6889E243-8065
1 Fault Found:
00003 - Control Module
014 - Defective
Address 19: CAN Gateway Labels: 1K0-907-530-V3.clb
Part No SW: 1K0 907 530 L HW: 1K0 907 951
Component: J533__Gateway H15 0180
Revision: H15 Serial number: 1400K078210CBF
Coding: E9807F060002020202
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO VO3 0424
Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX3.lbl
Part No SW: 1T0 959 701 G HW: 1K0 959 793 M
Component: J386 TUER-SG FT 1129
Revision: 31008001 Serial number: 00000520578717
Coding: 0000176
VCID: 3B75D1677A907BC6811-806E
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K1 909 144 M
Component: EPS_ZFLS Kl.077 H08 1901
VCID: 3561C75F5CB4ADB6775-8060
1 Fault Found:
00778 - Steering Angle Sensor (G85)
000 - -
dzaraider
ClubSEAT Team
Re: probleme unitate control comenzi volan si eroare airbag
12 Iul 2016, 13:56
Din cate vad eu, ai schimbat ceasurile si, cel putin in momentul scan-ului, nu ai facut adaptarea IMMO-ului. G85-ul are nevoie de o calibrare pentru a se "sterge" eroarea, nu are nici o legatura cu slip ring-ul sau calculatorul de coloana. Legat de comenzile pe volan, calculatorul pe care il ai pe coloana suporta functia asta dar, daca nu ai avut inainte asa ceva, probabil ca nu suporta slipring-ul. Pe langa asta trebuie sa si codezi cu vcds modulul respectiv ca sa recunoasca comenzile.
popa.andreialex
23 Aug 2016, 23:16
salut, iti multumesc pentru raspuns, plasticul de la slip ring e rupt, s-ar putea sa fie si ala.
