andleip
Erori gasite cu VAG
18 Ian 2016, 14:07
Buna ziua, am facut o scanare masinii si au iesit niste erori..imi poate spune cineva despre ce eroare este vorba? ar trebui sa schimb ceva?multumesc
Friday,15,January,2016,13:11:33:62939
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.0.0
Data version: 20130910
VIN: VSSZZZ1PZ7R017636 License Plate: ADRI1
Mileage: 185040km-114978mi Repair Order:
Chassis Type: 1P (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
VIN: VSSZZZ1PZ7R017636 Mileage: 185040km/114978miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine Labels: 03G-906-016-BKC.lbl
Part No SW: 03G 906 021 LK HW:
Component: R4 1,9L EDC G000SG 9249
Revision: --H02--- Serial number: SEZ7Z0F3547331
Coding: 0050071
Shop #: WSC 21202 136 87566
VCID: 73E539471240F386991-8026
No fault code found.
Readiness: 0 0 0 0 0
Address 03: ABS Brakes Labels: 1K0-907-379-MK70.lbl
Part No: 1K0 907 379 P
Component: ASR FRONT MK70 0105
Coding: 0000641
Shop #: WSC 06403 785 00200
VCID: 3F8DA5776E8867E6AD9-806A
Address 08: Auto HVAC Labels: 1K0-820-047.lbl
Part No: 5P0 820 047 K
Component: Climatic PQ35 011 0201
Shop #: WSC 00000 000 00000
VCID: 3561C75F5CB4ADB6775-8060
Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 E HW: 3C0 937 049 E
Component: Bordnetz-SG H37 1002
Revision: 00H37000 Serial number: 00000004209747
Coding: 81880F2F00041000001D00000000000000017F075C
VCID: 2B55E1278AF0EB46111-807E
Subsystem 1 - Part No: 1P0 955 119 A Labels: 1KX-955-119.CLB
Component: Wischer SE350 012 0403
Coding: 00056272
Shop #: WSC 06403
Address 15: Airbags Labels: 3C0-909-605.lbl
Part No SW: 3C0 909 605 L HW: 3C0 909 605 L
Component: R2 AIRBAG VW8 030 2522
Revision: 12030000 Serial number: 003B0PSFXBJG
Coding: 0021042
Shop #: WSC 81033 120 08486
VCID: 2F6DF537BEE897663D9-807A
Subsystem 1 - Serial number: 6332MSME1100084F
Subsystem 2 - Serial number: 6342MSME10626846
Subsystem 3 - Serial number: 6351HTS6PLLI23Q2
Subsystem 4 - Serial number: 6361HTS6PLLU4NL2
Subsystem 5 - Serial number: 00000000000000000
Subsystem 6 - Serial number: 00000000000000000
1 Fault Found:
00532 - Supply Voltage B+
002 - Lower Limit Exceeded - Intermittent
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 BC HW: 1K0 953 549 BC
Component: Lenksäulenmodul 636 0070
Coding: 0000042
VCID: 74E73A5B174EF4BE80B-8021
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No: 1P0 920 823 G
Component: KOMBIINSTRUMENT VO3 0422
Coding: 0002101
Shop #: WSC 00581 210 64475
VCID: 306FF64BA3D6889E243-8065
Address 19: CAN Gateway Labels: 1K0-907-530-V2.clb
Part No SW: 1K0 907 530 H HW: 1K0 907 951
Component: J533__Gateway H12 0150
Revision: H12 Serial number: 31001066148C54
Coding: 3D3F034007000202
VCID: 2C57E23B8FFEEC7E18B-8079
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO VO3 0422
Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX3.lbl
Part No SW: 1T0 959 701 G HW: 1K0 959 793 M
Component: J386 TUER-SG FT 1123
Revision: 31008001 Serial number: 00000533788127
Coding: 0004272
Shop #: WSC 12336 024 394758
VCID: 3B75D1677A907BC6811-806E
1 Fault Found:
01044 - Control Module Incorrectly Coded
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 01100101
Fault Priority: 6
Fault Frequency: 1
Reset counter: 101
Mileage: 44386 km
Time Indication: 0
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K1 909 144 L
Component: EPS_ZFLS Kl.077 H07 1806
VCID: 3467FA5B57CEB4BE40B-8061
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
Component: KSG PQ35 G2 020 0202
Revision: 00020000 Serial number: 00000000000000
Coding: 198000005283CC7F0006050560084F01207C80
VCID: 8305E987C2E04306091-80D6
Subsystem 1 - Component: Sounder n.mounted
Subsystem 2 - Component: NGS n.mounted
Subsystem 3 - Component: IRUE n.mounted
1 Fault Found:
00893 - Switch for Trunk Handle (E234)
007 - Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00100111
Fault Priority: 4
Fault Frequency: 2
Reset counter: 119
Time Indication: 0
Address 52: Door Elect, Pass.
Cannot be reached
Address 56: Radio Labels: 1K0-035-1xx-56.lbl
Part No: 1P1 035 186 B
Component: Radio BVX 0006
Coding: 0020414
1 Fault Found:
00874 - Treble Speaker Front Left (R20)
011 - Open Circuit
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 1K0 959 703 N HW: 1K0 959 795 H
Component: J388 TUER-SG HL 1103
Revision: 11004001 Serial number: 00000000190362
Coding: 0000144
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
Part No SW: 1K0 959 704 N HW: 1K0 959 794 H
Component: J389 TUER-SG HR 1103
Revision: 11004001 Serial number: 00000000196621
Coding: 0000144
VCID: 3C77D27B7F9E7CFE88B-8069
andleip
Re: Erori gasite cu VAG
19 Ian 2016, 10:13
nici o parere?
19 Ian 2016, 10:34
http://wiki.ross-tech.com/wiki/index.php/00532
http://wiki.ross-tech.com/wiki/index.php/01044
https://encrypted.google.com/search?{google:acceptedSuggestion}oq=00893+-+Switch+for+Trunk+Handle+(E234)&sourceid=chrome&ie=UTF-8&q=00893+-+Switch+for+Trunk+Handle+(E234)
https://encrypted.google.com/search?{google:acceptedSuggestion}oq=00874+-+Treble+Speaker+Front+Left+(R20)&sourceid=chrome&ie=UTF-8&q=00874+-+Treble+Speaker+Front+Left+(R20)
prima data se cauta pe site wiki ross tech, acolo gasesti posibile cauze si sugestii, apoi o cautare generica in google ajuta foarte mult, asta daca vrei explicatii tehnice detaliate. pe forum pot fi persoane care au avut sau nu problema, la unii se rezolva cu un spray sau sa miste un contact, la altii prin inlocuire, depinde de eroare, etc
19 Ian 2016, 10:41
In primul rand e o inadvertenta in scanare: in preview scrie ca usa pasagerului e ok, iar in scanare nu a putut fi interogat acel controler. Trebuie refacuta scanarea macar pentru acel modul - 52. Apoi ai o problema cu switch-ul din manerul portbagajului. Trebuie desfacuta fata de plastic si studiat. La airbaguri sterge doar eroarea, ai avut bateria decuplata sau foarte slaba candva si eroarea a aparut la pornirea motorului. La usa soferului trebuie vazut ce codare ar trebui sa fie si facuta calibrarea butonului de geam la executarea cursei geamului. Codarea posibil sa fie aceeasi ca la usa pasagerului, deci refa scanarea.
andleip
19 Ian 2016, 11:26
multumesc frumos pentru raspunsuri
alex presa
22 Feb 2016, 11:07
Salut. Am facut si eu o scanare la o Ibiza 1.4 TDI, iar astea ar fi erorile. Daca poate cineva sa imi spuna mai mult decat am gasit pe ros-tech. Probleme la mine ar fi ca uneori nu porneste la prima cheie, de obicei cand motorul este cald, cand pornesc dimineata se aprinde in bord indicatorul casetei de directie, oprit dupa cateva minute si pornit iar se stinge. o alta problema ar fi ca nu se schimba temperatura decat dupa ce opresc sau pornesc clima de mai multe ori. Multumesc!
Address 01: Engine Labels: 045-906-019-AMF.clb
Part No: 045 906 019 BB
Component: 1,4l R3 EDC G000SG 1556
Coding: 00002
Shop #: WSC 06402
VCID: 56A5F003B2858FAE9EF-4A3A
VSSZZZ6LZ3R222129 SEZ7Z0C2013699
2 Faults Found:
17911 - Load Signal from Alternator Term. DF
P1503 - 35-10 - Implausible Signal - Intermittent
19463 - Camshaft Position Sensor (G40)
P3007 - 35-10 - No Signal - Intermittent
Readiness: 0 0 X X X
Address 08: Auto HVAC Labels: 6Q0-820-045.lbl
Part No: 6L0 820 045
Component: Klimaanlage X0840
VCID: E5C747CF7FE39436875-5000
4 Faults Found:
65535 - Internal Control Module Memory Error
00-00 - -
01271 - Positioning Motor for Temperature Flap (V68)
30-00 - Open or Short to Plus
29-10 - Short to Ground - Intermittent
28-10 - Short to Plus - Intermittent
Address 09: Cent. Elect. Labels: 6Qx-937-049-C.lbl
Part No: 6Q1 937 049 C
Component: 00 BN-SG. 1S33
Coding: 00012
Shop #: WSC 06402
VCID: 3B7341B729E772C6811-5072
1 Fault Found:
01598 - Drive Battery Voltage
07-10 - Signal too Low - Intermittent
