DDaniel
Localitate: Falticeni, Suceava
Probleme sonda lambda
07 Dec 2015, 19:47
Nu am o problema decat in scanare, masina merge bine, trage, atat cat poate motorul de 1.6, relantiul e OK. Mentionez ca sonda e schimbata cu un de la dezmemrari cei drept.
Address 01: Engine Labels: 06A-906-033-BGU.lbl
Control Module Part Number: 06A 906 033 DA
Component and/or Version: SIMOS71 1.6l 2V 8422
Software Coding: 0000071
Work Shop Code: WSC 80620 120 183070
VCID: 61C3D420B852B56
2 Faults Found:
19617 - Linear Oxygen (Lambda) Sensor B1 S1; Pump Current Wire
P3161 - 008 - Open Circuit - Intermittent - MIL ON
Freeze Frame:
RPM: 1792 /min
Bin. Bits: 00100000
Voltage: 5.100 V
Voltage: 0.040 V
RPM: 1856 /min
Bin. Bits: 00100000
Voltage: 5.060 V
Voltage: 0.040 V
18047 - Accelerator Position Sensor 1/2 (G79/G185)
P1639 - 008 - Implausible Signal - Intermittent
Freeze Frame:
RPM: 2080 /min
Absolute Pres.: 303.2 mbar
Load: 20.8 %
Load: 12.5 %
Readiness: 0000 1100
