Adysor
Localitate: Baia Mare
probleme climatronic
29 Noi 2015, 20:42
Buna seara tuturor. Ma poate ajuta si pe mine cineva Sunday,29,November,2015,19:01:50:55062
VCDS Version: Beta 12.10.3
Data version: 20130228
Chassis Type: 1M - Seat Toledo II
Scan: 01 02 03 08 15 17 19 22 35 36 37 46 56
Mileage: 243330km/151198miles
Address 01: Engine Labels: 038-906-012-AGR.lbl
Part No: 038 906 012 AA
Component: 1,9l R4 EDC G000SG 2514
Coding: 00002
Shop #: WSC 00046
VCID: 4FA6C4568D0A3A6646F
No fault code found.
Readiness: N/A
Address 03: ABS Brakes Labels: 1J0-907-37x-ABS.lbl
Part No: 1J0 907 379 P
Component: ABS 20 IE CAN 0001
Coding: 03304
Shop #: WSC 00046
VCID: 3E7889923AA0A3EEBD9
Address 08: Auto HVAC Labels: 1M0-820-043.lbl
Part No: 1M0 820 043 C
Component: 1M-CLIMATRONIC X0603
Coding: 00043
Shop #: WSC 00046
VCID: 22405DE2AE18E70EB91
3 Faults Found
00603 - Footwell/defroster Flap Positioning Motor (V85)
41-00 - Blocked or No Voltage
01272 - Positioning Motor for Central Flap (V70)
41-10 - Blocked or No Voltage - Intermittent
00600 - Potentiometer On Positioning Motor for Temperature Flap (G92)
30-00 - Open or Short to Plus
Address 15: Airbags Labels: 1J0-909-60x-VW3.lbl
Part No: 1J0 909 609
Component: L AIRBAG VW3 SG 0002
Coding: 00076
Shop #: WSC 00046
VCID: ECDCF3DA9C5C617EC3D
Address 17: Instruments Labels: 1M0-920-xx0-17.lbl
Part No: 1M0 920 820 EV
Component: S5-KOMBIINSTR. VDO V15
Coding: 04142
Shop #: WSC 00001
VCID: 7EF849927A2063EEFD9
Subsystem 1 - Part No: IMMO
Component: IDENTNR: SEZ7Z0Y0674232
IMMO-IDENTNR: SEZ7Z0Y0674232
2 Faults Found
00667 - Ambient Temperature Signal
30-10 - Open or Short to Plus - Intermittent
29-10 - Short to Ground - Intermittent
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00002
Shop #: WSC 00000
VCID: F0E4E7AAB074859EFF5
Address 46: Central Conv. Labels: 1J0-959-799.lbl
Part No: 1J0 959 799 AH
Component: 3U Zentral-SG Komf. 0001
Coding: 04097
Shop #: WSC 00046
VCID: 840CBB7A94CC893E2BD
Subsystem 1 - Part No: 1J0959801F
Component: 3U Tõrsteuerger. FS0002r
Subsystem 2 - Part No: 1J0959802G
Component: 3U Tõrsteuerger. BF0002B
Subsystem 3 - Part No: 1J4959811C
Component: 3U Tõrsteuerger. HL0002r
Subsystem 4 - Part No: 1J4959812C
Component: 3U Tõrsteuerger. HR0002r
2 Faults Found
00953 - Interior Light Time limit
25-10 - Unknown Switch Condition - Intermittent
00934 - Electric Window Motor; Rear Left (V26)
62-10 - No or Incorrect Adjustment - Intermittent
Re: probleme climatronic
29 Noi 2015, 21:21
La clima sunt murdare potentiometrele de pe acele motorase ce plimba clapetele respective. Cam greu de curatat si sa mearga bine dupa. Mai simplu, dar mai costisitor ar fi de inlocuit cu altele noi.
La centralizata schimba siguranta 14, desi cea de acum nu e arsa. Pune una noua, nu una recuperata.
La bord nu ai senzor de temperatura ambianta, ala e in climatronic. Trebuie investigata problema, mai sigur ceva probleme de contact sau vreo lipitura rece.
Adysor
02 Dec 2015, 23:09
ok ms de ajutor, in bord imi arata temperatura exterioata timp de 5 minute dupa care imi apar 3 liniute ---, in timp ce conduc masina cu climatronicu pornit pe dezaburire imi sufla ba la picioare ba pe centru ba intra pe auto, primesc motorasele comanda. stau cu masina la semafor cu climatronicu oprit si imi cupleaza compresoru de clima timp de 2 sec decupleaza 2 secunde cupleaza inapoi 2 sec, si inca ceva am observat ca releu de climatronic de sub baterie a fost inlocuit si ii montat cu ultima litera K normal trebuia Q pe toate toledo cu climatronic am vazut Q la mine ii K, am schimbat comanda de climatronic a functionat o perioada perfect si de sambata face iar aceleasi figuri cu cealalta comanda nu mai functiona nici un motoras, am dat-o la un meserias electronist si a refacut lipiturile reci dar degeaba nu mai functioneaza nu mai stiu ce sa fac vreau sa trec pe butoane manuale clasic
03 Dec 2015, 08:40
Ca sa treci pe butoane clasice e la fel de greu ca la trecerea pe climatronic. Adica iti va trebui schumbata toata tubulatura de sub bord cu panoul de comanda aferent si refacut instalatia electrica. Trebuie pus inca un senzor de temperatura sub grila stergatoarelor si schimbat senzorul de presiune de pe tevile de freon. Destul de lucru.
Ai schimbat motorasele respective? Degeaba schimbi panoul de comanda daca motorasele tot defecte sunt. Masina de pe care am luat eu instalatia avea releu cu K si l-am lasat pe al meu cu Q, ca sa nu mai desfac destule pe-acolo doar. Daca ai dubii cauta un releu cu Q si vezi cum se comporta, dar in interior tot rau va fi din cauza motoraselor.
Adysor
03 Dec 2015, 22:23
ok ms de informatie o sa curat potentiometrele la motorase si o sa vedem ce se intampla
