  • 12
  • 13
  • 14
  • 15
  • 16
  • 43
Re: Leon Cupra R - 1M
17 Ian 2016, 09:45
Multumim pentru info.
Sent by me.
17 Ian 2016, 10:39
Multumesc si eu sony!
O sa vorbesc cu dany19940, iar in primavara cand o sa a ajunga masina la el, o sa vad daca e mai rentabil sa-l repar la nenea unde si l-a facut si el, sau sa inlocuiesc tot buretele.
17 Ian 2016, 11:32
Pai...vorbeste! :yh
17 Ian 2016, 11:36
Nu stiu exact data cand o sa ajunga masina la tine.
18 Ian 2016, 10:30
Iata si decodarea completa a seriei de sasiu.
Interesant este ca masina fost fabricata la 27.02.2003 iar prima inmatriculare a fost pe 14.01.2004. Se pare ca masina a stat in showroom pt mult timp.
Numar sasiu VSSZZZ1MZ3R105780
Cod vanzare 1M1516
An model 2003
Model LE
Denumire model Leon Cupra
Cod motor AMK
Cod cutie viteze FML
Tip transmisie 6S
Dotare GX
Culoare plafon 1V
Culoare exterioara/Cod vopsea 1V/S1H
Data fabricatie 27.02.2003
A8F Sports equipment
AZ0 Vehicle with standard production scope
B0V Component parts set, complying with vehicle type for the Netherlands various parts
B31 Type approval the Netherlands
C21 Operating permit, alteration
CV4 Alloy wheels 7.5J x 18
E5K "Cupra R"
F0A No special purpose vehicle, standard equipment
G0K 6-speed manual transmission
G92 Front shock absorption
H3L Reifen 225/40 ZR18
J1L Battery 280 A (60 Ah)
K8G Hatchback
L05 Suspension range 05 installation control only, no requirement forecast
L0L Left-hand drive vehicle
MK1 4-cyl. turbo gas. eng. 1.8 L/154 kW 20V appendix EU 3 base engine is T6B
N2Z Seat covering for special editions
PAV volumetric alarm
Q2Q RECARO sports seats, front
QA0 Without child seat
QG2 No possibility of activating service interval prolongation
QS0 Without electronic map cooling system
QZ7 Power steering
T6B 4-cylinder gasoline engine 1.8 L unit 06A.G
U0C Instrument insert with tachometer clock and km/h speedometer
UA2 Rear shock absorption
0A2 4 doors
0AQ Front stabilizer
0BB Rear stabilizer
0CK Vehicle class differentiation 1M0
0EN Installation differentiation for transmission MQ 350 vehicle components
0F2 Fuel system for carburetor gasoline engine
0FA Standard manufacturing sequence
0G4 Cable gearshift
0GE Emission standard EU3
0KA Without stickers and badges
0L2 Electric throttle actuation
0N5 Standard rear axle
0NA Without nameplate set (without model designation)
0RA Without ignition/starter switch locking system
0SE Labels/plates in Dutch
0TA Without floor mats
0UA Without special color trim
0VH Information kit in Dutch
0YZ Without determination of weight category for rear axle
1AT Electronic stabilization program (ESP)
1C1 Antifreeze up to -25 degree celsius tolerance up to -30 degree C
1D3 Vorbereitung mit verstärkter Kühlung
1E1 Activated carbon canister
1EX Spezielles Typschild für EG
1G3 Alloy spare wheel with original equipment tires
1H0 Without proportioning valve
1LT Disc brakes, front
1NL Covers for alloy wheels
1PC Wheel bolts with anti-theft protection (unlockable)
1Q0 Without mass damper for steering wheel
1S1 Tool kit and jack
1SF Additional engine and transmission guard
1T0 Without first aid kit and warning triangle
1X0 Front wheel drive
1Z2 Increase in initial standard fuel filling
2B9 Additional exterior noise suppression
2C5 Axial and vertical adjustable steering column
2D1 Complete cd enhancing underbody panel
2EM Disc brakes, rear
2G9 Filler neck module 2 with insert
2JP Stoßfänger, lackiert, abweichend zur Wagenfarbe
2LB Fuel tank with special material treatment
2PX Leather trimmed sports steering wheel
2UA Standard design
2V1 Dust and pollen filter
2W0 Fuel filler cap
2WA Without additional tires
3B0 Without additional child seat anchor
3C1 Static lap belt, center rear
3CA Without partition
3FA Without roof insert (standard roof)
3GA Without cargo area
3H0 Without backrest release for front seats
3J7 Articulated and height-adjustable headrests for front seats
3L3 Manual height adjustment for front seats
3M0 Without special measures
3NW Rear seat bench/backrest, split folding with center armrest
3P1 Bracket for first aid kit and warning triangle
3Q1 Rear headrests
3S0 Without roof rails/roof load rack
3U1 Foldable trunk cover
3Y0 Without roll-up sun screen
3YQ Door pockets without insert mats
3ZM 3-point seat belts, outer rear
4A0 Without seat heater
4AF Door and side trim panel in foam film and woven fabric
4B2 Body-colored protective side molding
4E0 Tailgate/trunk lid unlocking from outside
4GF Windshield in heat-insulating glass
4J5 Floor tray, extension center console
4K3 Radio remote controlled central locking
operated from inside and safe securing
4KC Side and rear windows in heat-insulating glass
4L2 Dipping breakaway interior rear view mirror
4LA Without controls
4M5 Cup holder
4N1 Padded dashboard
4P0 Rear floor panel module, type 1
4Q1 Flame retardent materials
4QU 3-point seat belts front w/ tensioner (electr.) and height adjustment
4R4 Power windows with comfort operation and circuit breaker
4SC Left vanity mirror with cover
4TC Right vanity mirror with cover
4U3 Luggage net on backrest, right seat
4UF Driver's and front passenger air bag with front passenger air bag deactivation
4W0 Without cassette and CD storage unit
4X1 Side air bag front
4XC Exterior pillar lining
5A2 Comfort trunk lining
5C0 Without special body measures
5D1 Carrier frequency 433.92 MHz-434.42 Mhz
5J7 Body-colored rear spoiler (version 4)
5K1 Paint preservative (wax)
5N6 Folding grab handles at roof frame soft fold-away
5RQ Right exterior mirror: convex
5SL Left exterior mirror: aspherical
5TC Without decorative inserts
6A0 Without fire extinguisher
6E0 Without center armrest front
6EB Additional body covers, stone guard and partial trim plate
6FF Body-colored exterior mirror housings and various add-on parts
6KA Radiator grille
6NA Unsplit molding roof liner
6P0 Without license plate bracket rear
6PC Leather hand brake lever handle
6QA Rear seat catch
6R2 Leather gearshift boot
6SC Tufted trunk floor covering
6W0 Without license plate bracket front
6XE Exterior mirrors: electrically foldable
and electrically adjustable/heated
6Y0 Without cruise control warning system
7A0 Without CD changer/CD player
7B2 12-volt socket in luggage boot
7E0 W/o heat accumulator/auxiliary heating
7F0 Leather gearshift knob with titanium appearance
7P4 Manually adjustable lumbar support in front seats
7PB Platform group class 2
7Q0 Without navigation device
7QA Without CD/DVD for navigation
7R3 Side turn signal lights (white)
7X0 Without park distance control
8BB Halogen headlight for driving on the right
8CC Speedometer sensor without seal (electronic speedometer sensor)
8E2 Local interference suppression for FM/AM radio reception
8GL Alternator 120 A
8K0 Without special headlight activation
8KA W/o catalytic converter warning light
8L3 Roof antenna
8M1 Rear window wiper and washer system with intermittent control
8MA Without headphone port rear
8N4 Windshield wiper intermittent control with potentiometer (four speeds)
8P1 Heated rear window
8Q1 Headlight-range adjustment
8QK Key for locking system
8RM 8 speakers (passive)
8S2 One reading light front, two reading lights rear
8SA Taillight assemblies, standard design
8T0 Without cruise control system (CCS)
8TF Rear fog lights, left and right
8UE Radio with CD drive
8W1 Washer fluid level indicator
8WD Integrated front fog light
8X0 Without headlight washer system
8Y1 Two-tone horn
8Z5 Not hot country
9A0 Without taxi alarm system
9AK Climatronic with impact pressure control free of cfc
9D0 Without preparation for two-way radio installation
9FA Without automatic transmission indicator light
9GB Interior light with switch-off delay and door pillar switch
9J0 Without supertone system and tone sequence control
9JB Smoking package, ashtray front and rear
9M0 Without auxiliary/parking heater
9P0 Without seat belt reminder
9Q1 Multi-function display/on-board computer
9T0 Without heated washer nozzles
9TB Additional warning lights (door area)
9U1 Brake pad wear indicator
9V7 Electronic vehicle immobilization device with anti-theft alarm system and passenger compartment control
9W0 W/o car phone preparation/installation
9X0 Without heated door lock cylinder
9Y1 Outdoor temperature gage
20 Ian 2016, 14:46
Avem si numere, am facut si geometria, am reglat si farurile, pus benzina si am iesit din barlog....
20 Ian 2016, 14:53
:yah de cand asteapta sa fie plimbata...,sa fie intr-un ceas bun. :drive
EX: LEON 1.4 16V Kit FR
20 Ian 2016, 15:05
:yah Merci Mylux :hi
20 Ian 2016, 16:23
Buun,acum te poti bucura pe deplin de ea :)
Asteptam impresii dupa cateva zile
Localitate: Brasov / Sacele
20 Ian 2016, 17:46
Sa te duca unde vrei fara griji si probleme :-)
Seat toledo nh Tsi Imagine
Localitate: Bistrita
20 Ian 2016, 17:52
Asteptam impresii ...poze, pareri... :)
My Toledo 1.9 TDI
20 Ian 2016, 19:02
Sau poate la un tester mai bine zis. A pornit la a 3-a cheie in seara asta. Poate nu i-a placut Vpower-ul :(
21 Ian 2016, 00:26
Aceeasi figura mi-a facut-o iar in seara asta: a pornit abia la a3-a cheie. De invartit invarte normal, nu ar da semne ca e de la baterie. In schimb am mai observat ca la prima si a 2-a tentativa, dupa ce pun contactul, martorul ESP ramane aprins in bord. A 3-a oara, se stinge si porneste ceas. Ori are legtura cu geometria, ori cu benzina. Astea sunt singurele schimbari de cand am luat masina.
21 Ian 2016, 00:42
Asa ca un long shot arunca-ti un ochi daca ai vreo eroare de senzor de pozitie axa came......
  • 12
  • 13
  • 14
  • 15
  • 16
  • 43
