boditza
Codari OPS
04 Oct 2015, 16:19
Pe masina mea am senzori de parcare din fabrica si as vrea sa ii fac sa afiseze pe RNS510.
Am incercat fel si fel de codari insa nu am reusit sa ii fac sa mearga. Mai mult imi da si o eroare pe Park/Steer Assist cu codarea actuala:
Address 10: Park/Steer Assist (J446) Labels: 1K0-919-475.clb
Part No SW: 1K0 919 475 A HW: 1K0 919 475 A
Component: PARKHILFE 005 1104
Revision: 00005000 Serial number: 0 263 004 194
Coding: 101101
Shop #: WSC 04941 000 00000
VCID: 306B14F3DAB3
1 Fault Found:
00830 - Convertible Top Control Module (J256)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 4
Fault Frequency: 97
Reset counter: 154
Mileage: 222735 km
Time Indication: 0
Date: 2000.00.00
Time: 12:26:28
Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
Part No SW: 1T0 035 680 P HW: 1T0 035 680 P
Component: RNS-MID H08 5218
Revision: AB001001 Serial number: VWZ6Z7M6311053
Coding: 02000400040000A20000
Shop #: WSC 05314 000 00000
ASAM Dataset: ------------------------- ------
VCID: 3B7133DF03F5
Part No: 7N5 919 859 A
Component: EU East V12 8196
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 P HW: 1K0 907 951
Component: J533__Gateway H16 0191
Revision: H16 Serial number: 2000K07A080285
Coding: EDA07F064002020202
Shop #: WSC 04941 785 00200
VCID: 346318E32EAB
Daca poate cineva sa posteze codarile functionale de pe 1P aici.
Re: Codari OPS
05 Oct 2015, 20:52
Dupa parerea mea conteaza si FW de pe RNS. Sau chiar versiunea de pe Can-gateway.
Eroarea aceea este pe trapa !?, eu asa o interpretez
MAi asteapta si alte pareri ... :hi
mihai p
Localitate: Slobozia
Re: Codari OPS
06 Oct 2015, 03:54
De la inceput ai avut senzorii pe adresa 10 sau ai schimbat unitatea de PDC cu una pentru OPS ?
- SEAT ALTEA FREETRACK 2008 2.0 TDI
RD-Woo
Localitate: Alexandria
Re: Codari OPS
06 Oct 2015, 08:07
boditza scrie:
[10-Assistance stationnt] -> [Security-16] (code 71679) -> [Codage-07] -> [Assistant Codage Long]
Octet 0:
Bit 4: Cocher "Optical illustration active"
Re: Codari OPS
06 Oct 2015, 08:59
Codarea pe adresa 10 e gresita, nu ai model cabrio. Insa degeaba codezi corect, OPS funtioneaza cu gateway 1K revizie minim AA.
Pune scan de pe adresa 19.
boditza
Re: Codari OPS
07 Oct 2015, 00:19
Salut tuturor,
Scan-ul pe adresa 19:
VCID: 346318E32EAB
Senzorii au fost mereu pe adresa 10, nu am facut nici o modificare la masina in afara de montarea RNS care este plug&play-ish.
Cosmin daca esti sigur de CAN ca imi trebuie altul inseamna ca de ce imi era frica nu scap. Desi pe site-ul ROSS TECH can-ul meu ar trebui sa sufere de battery drain nu este deloc asa. Sta masina si 2 saptamani nepornita si nu are nici o problema. Am evitat sa o schimb din motive de indemanare la montare si datorita faptului ca nu am gasit interfata originala in Craiova(nici nu am cautat prea mult ce-i drept), care numai cu ea s-ar coda can-ul.
RD-Woo
Re: Codari OPS
27 Dec 2015, 02:42
boditza scrie:
In week-end am reusit sa afisez senzorii de parcare (din fabrica) pe display-ul unitatii audio RCD-310.
Codare pe adresa 07 (Bit 4)
RD-Woo
Re: Codari OPS
23 Feb 2016, 19:09
RD-Woo scrie:
Optiunea de afisare s-a pastrat si dupa schimbarea unitatii audio originale cu RCD 510
ImaginexImagine
RD-Woo
Re: Codari OPS
15 Mar 2016, 18:42
Cosmin scrie:
Ar merge si full OPS
Da, cam la acelasi lucru ma gandeam :P acum sunt in faza pregatirii pt full OPS
momentan am achizitionat panoul de comanda cu butoane care il include pe cel de activare al senzorilor,
ulterior ma orientez la comandarea celor pt fata, intrucat pe spate sunt montati din fabrica 8)
Imagine x Imagine x Imagine
Re: Codari OPS
16 Mar 2016, 10:39
Trebuie unitate noua OPS, ce ai tu pe masina suporta doar senzori spate. Nu o sa functioneze cand adaugi si senzorii fata.
Pe langa unitate ce stie 8 senzori, mai e nevoie de cablaje (unitate - intermediar bara fata - senzori).
