lucky2004alex
Localitate: Cluj
Diagnoza Seat Leon 1M 1.6 16v
08 Mai 2015, 13:16
Buna tuturor,
NU am mai fost de mult pe forum.Recent am fost in CLuj la o intalnire VW.Nu stiu daca este intalnire Seat in CLuj.
Am facut o scurta diagnoza si am constatat ca Leonul da semne de oboseala.
Imi poate traduce si mie ce si cum , si daca stie in zona clujului ceva omulet indicat pt operatie?
ms frumos
Wednesday,06,May,2015,20:53:43:62939
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.0.0
Data version: 20130910
VIN: VSSZZZ1MZ4R069456 License Plate:
Mileage: 173380km-107733mi Repair Order:
Chassis Type: 1M (1M - Seat Leon (2000 > 2005))
Scan: 01 02 03 08 15 17 19 22 35 36 37 46 56
VIN: VSSZZZ1MZ4R069456 Mileage: 173380km/107733miles
Part No: 036 906 034 DS
Component: MARELLI 4MV 4568
Coding: 00031
Shop #: WSC 06402
VCID: 66C350130292162E0EF-4A3A
VSSZZZ1MZ4R069456 SEZ7Z0C2296490
3 Faults Found:
17586 - Linear O2 Sensor; Pump Current
P1178 - 35-10 - Open Circuit - Intermittent
17598 - Linear O2 Sensor; Reference Voltage
P1190 - 35-10 - Implausible - Intermittent
17550 - Load Calculation Cross Check
P1142 - 35-10 - Lower Limit Exceeded - Intermittent
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 1C0-907-37x-ABS.lbl
Part No: 1C0 907 379 L
Component: ABS FRONT MK60 0101
Coding: 0001025
Shop #: WSC 00001 001 00001
VCID: 3365F94751C0B386591-5000
No fault code found.
Part No: 1C0 909 605 A
Component: 39 AIRBAG VW51 0A 0008
Coding: 13113
Shop #: WSC 06401
VCID: 224B0C03AE3A2A0EA27-5000
Address 17: Instruments Labels: 1M0-920-xx2-17.lbl
Part No: 1M0 920 802 A
Component: KOMBI+WEGFAHRSP VDO V05
Coding: 04106
Shop #: WSC 00000
VCID: 24470A1BB42E243ED0B-5000
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 06402
VCID: F0EFB64BB056489EE43-5072
Address 46: Central Conv. Labels: 1C0-959-799.lbl
Part No: 1C0 959 799 E
Component: 99 Komfortgerát HLO 0003
Coding: 00067
Shop #: WSC 49875
VCID: 3979CB6F23AC49D693D-49D8
Subsystem 1 - Part No: 1C1959801A
Component: 99 Tõrsteuer.FS KLO 0202
Subsystem 2 - Part No: 1C1959802A
Component: 99 Tõrsteuer.BF KLO 0202
Re: Diagnoza Seat Leon 1M 1.6 16v
13 Mai 2015, 05:16
O2 = oxygen
...sonda Lambda...verifica mai intai firele de sub masina, poate nu mai sunt intregi 100% :hi
....dar totusi daca totul este in ordine, mai exista un Pre lambda senzor!!! , acela esteO2 linear
lucky2004alex
Localitate: Cluj
13 Mai 2015, 07:35
MS.Trebuie sa gasesc sa o urc unedeva sus.Mi s-a agatat l ao trecere de calea ferata (drumurile romaniei bune) , racordul flexibil, iesirea evacuarii din motor.
A trebuit sa o schimb, si atunci, meseriasii care au sudat -o, cred ca au rupt si ceva fire pe acolo.De atunci am eroare in bord.
Ce e drept scred ca scapa si aer ...cand accelerez pe liber se aude un fasait.
Soso-CKX
13 Mai 2015, 14:10
Daca nu au etansat bine la sudura, iti trage aer fals pe acolo si astfel pacaleste sonda lambda 2 ca, catalizatorul e intr-o stare diferita de cea reala. Mi se pare ca la o adica poate interveni si sonda asta in amestecul carburant si de-aici lipsa de putere pentru ca nu e optim.
E improbabil sa fi agatat firele de la sonda 2 pentru ca e destul de departe de locul unde au avut ei treaba cu racordul flexibil.
lucky2004alex
Localitate: Cluj
14 Mai 2015, 07:49
Am inteles.Cel mai bine este sa o ridic pe un elevator sa verific.MS frumos
