Alexander94
ABS senzor
01 Mar 2015, 19:54
Salut, nu demult am in bord aprins becul ABS, si cateodata se si stinge. La viteza mica, atunci cand apas fransa intra brusc ABS-ul, am chemat pe cineva cu un tester si as vrea un mic ajutor. Va pun mai jos rezultatele, daca se poate sa ma ajutati cu un raspuns la eroare, si cam ce ar trebuii sa cumpar, ma astept la un senzor nou...nu stiu. Va multumesc !!
Sunday,01,March,2015,16:22:31:65217
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: Release 12.12.0 (x64)
Data version: 20130910
VIN: VSSZZZ6LZ6R070132 License Plate: ALEX
Mileage: 239190km-148625mi Repair Order:
Chassis Type: 6L (6L - Seat Ibiza/Cordoba (2002 > 2009))
Scan: 01 02 03 08 09 15 17 19 25 37 44 46 55 56
VIN: VSSZZZ6LZ6R070132 Mileage: 239190km/148625miles
Part No: 045 906 019 BS
Component: 1,4l R3 EDC 0000SG 7359
Coding: 00102
Shop #: WSC 06402
VCID: 67D7A3DC05931526359-49D8
VSSZZZ6LZ6R070132 SEZ7Z0E3070213
No fault code found.
Readiness: 0 0 0 0 0
Address 03: ABS Brakes Labels: 6R0-907-37x-ABS80.lbl
Part No SW: 6Q0 907 379 AF HW: 6Q0 907 379 AF
Component: ABS 8.0 front H04 0002
Revision: 00000000 Serial number: 00000000000000
Coding: 0002160
Shop #: WSC 06403 785 00200
VCID: 81031D44DBF74B161BD-5072
1 Fault Found:
00285 - ABS Wheel Speed Sensor; Front Right (G45)
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 2
Fault Frequency: 20
Reset counter: 48
Mileage: 239051 km
Time Indication: 0
Address 08: Auto HVAC Labels: None
Part No: 6L0 820 043 E
Component: CLIMAtronic PQ24 0505
Shop #: WSC 00000 000 00000
VCID: 2855E0E0980DDA5EFC3-50E6
1 Fault Found:
00710 - Defroster Flap Positioning Motor (V107)
000 - - - Intermittent
Address 09: Cent. Elect. Labels: 6Qx-937-049-C.lbl
Part No: 6Q1 937 049 D
Component: 0000 BN-SG. 1S34
Coding: 00012
Shop #: WSC 06402
VCID: 3C7D2CB02C9566FE88B-5072
Part No: 6Q0 909 605 AD
Component: 03 AIRBAG VW5 0010
Coding: 12339
Shop #: WSC 06401
VCID: 79F3F5A4632793D6D3D-5072
Address 17: Instruments Labels: 6L0-920-xx0-17.lbl
Part No: 6L0 920 801 A
Component: KOMBI+WEGFAHRSP VDO V13
Coding: 00135
Shop #: WSC 00000
VCID: 2757E3DCC513D526F59-5072
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: 0068 GATEWAY CAN 1S34
Coding: 00014
Shop #: WSC 06402
VCID: F0E54880B05D529EE43-5072
Address 44: Steering Assist Labels: 6Q0-423-156.clb
Part No: 6Q0 423 156 AB
Component: LenkhilfeTRW V270
Coding: 10111
Shop #: WSC 06402
VCID: 6FE7CBFC2D63CD667D9-5000
Address 46: Central Conv. Labels: 6Q0-959-433.lbl
Part No: 6Q0 959 433 E
Component: Komfortgerát 0002
Coding: 00016
Shop #: WSC 06402
VCID: 3D7B21B4378F6FF6BF5-4A9C
Re: ABS senzor
01 Mar 2015, 21:35
Mai degraba trebuie curatat de noroi si alte mizerii de acolo, se mai prinde si rugina uneori ce poate "aburi" senzorul. El da semnal, dar modulul ABS vede ca nu are aceeasi valoare cu cel din stanga (ai ABS doar pe fata din cate vad). Din cauza asta apare ca eroare semnalul implauzibil. Daca era senzor dus, aparea eroare in circuitul electric, adica cu totul alta.
Alexander94
Re: ABS senzor
01 Mar 2015, 22:34
Deci indicat ar fii mai intai sa dau roata jos sa verific senzorul?
Re: ABS senzor
02 Mar 2015, 09:24
Sa dai roata jos sa verifici sa nu ai diverse agatate pe-acolo, cred ca am explicat destul de bine.
Bamse
Re: ABS senzor
02 Mar 2015, 18:30
si eu am patit la fel, la inceput se aprindea martor abs si nu mai aveam abs, si pana sa intre intra abs la orice franare normala....fara sa fie nevoie de interventia sistemului.
Se poate la un mecanic sa iti scoata senzorul de la roata si sa il verifice, sa iti spuna daca e dus sau nu....Eu l-am avut dus, l-am schimbat si e ok.
Re: ABS senzor
02 Mar 2015, 19:04
Am avut si eu o problema cu un senzor la roata fata dreapta si a fost din cauza unui mecanic care mi-a schimbat arcurile si i-a cazut etrierul de pe platetara, iar niste papucei s-au smuls.
A trebuit sa scoata senzorul si sa-l repare.
Re: ABS senzor
02 Mar 2015, 23:04
Senzorul se masoara pe pozitie cu un ohmmetru,ar trebuie sa aiba in jur de 1,1 Kohmi. Daca are mai mult sau sau deloc, e clar ca e dus. Daca e bun, atunci se trece la verificarea rozetei de pe planetara, sa nu aiba mizerie intre dintii ce trec prin fata senzorului. Daca senzorul e dus, defectul dat e "fault in electrical system". Daca e bun si e doar mizerie, atunci e faultul aparut tie - "implausible signal", daca e si intermitent atunci esti si mai norocos ca poti scapa usor. Azi am schimbat 2 senzori pe fata la o Octavie si un Golf 4, amandoi cu rezistenta peste 3 Mohmi. Au iesit doar prin distrugere, iar cei noi au opus ceva rezistenta la intrarea in gaura si a trebuit sa folosesc smirghel, atat la gaura cat si la senzor chiar. Amandoua au mers perfect dupa inlocuire. Deci...spor la verificari!
