  • 11
  • 12
  • 13
  • 14
  • 15
  • 146
corsi
Re: Montaj elemente electronice, adaptari si recodari VAG COM
21 Apr 2009, 18:47
salut,
am un leon 1M si m-ar interesa daca stii sa-mi spui care din cele 61 de functii(ale climatronicului) indica temperatura in admisie.
mersi!
momentan skoda o3 184cp 4x4
22 Apr 2009, 08:20
Corsi,
Din cate stiu eu, acest parametru nu e masurat (daca vorbim de temperatura aerului care intra in motor). E masurata, printre altele, doar temperatura aerului admis in circuitul de climatizare.
Dar la ce te ajuta sa stii temeratura aerului in admisie?
Sima,
Incearca pe alt canal sau ia-le la rand. Trebuie sa fie pe undeva.
corsi
22 Apr 2009, 08:44
da,e vorba de aerul din admisie.
de masurat e masurat sigur dar nu stiu daca il pot afla cu functia asta.
voiam sa o monitorizez putin in zilele calde pt. a vedea daca intercooler-ul isi face treaba suficient de bine.Poate ii fac un upgrade.
Malaciuca
23 Apr 2009, 14:23
Voila, Preturi in Ron cu TVA :)
Halogen twin headlight unit for gas discharge bulb left 1P1 941 039 A -- 1,404.62
Halogen twin headlight unit for gas discharge bulb right 1P1 941 040 A -- 1,018.01
Headlight range control motor - headlight for gas discharge bulb 1P0 941 295 B - 2 buc. 235.44X2
Protective cap for low beam left 1P0 941 607-- 40.20
Protective cap for low beam right 1P0 941 608 40.20
Cover cap 7L6 941 607 - 2 buc. 51.48X2
Gas discharge bulb N 105 661 03 - 2 buc. 1,166.47X2
Control unit for gas discharge bulb 4L0 907 391 - 2 buc.
Headlight for cornering with static cornering light left 1P1 941 753 2,110.93
Headlight for cornering with static cornering light right 1P1 941 754 2,047.44
Control unit for cornering light 5M0 907 357 702.49
Power module for halogen twin headlights with gas discharge bulb 7L6 941 329 A - 2 buc. 945.54X2
Self levelling sensor with linkage front 1K0 941 247 B 433.78
Self levelling sensor with linkage rear 1K0 941 273 E 438.65
Seat Leon 1p 1.9 TDI 144cp RBN-RULZ!
verdesdoru
23 Apr 2009, 14:27
ghita_celofan scrie:
Doru, ordinea operatiilor e corecta. Insa din cate stiu eu, ti se va reseta consumul si tripul la BC.
Totusi, ar fi bine sa verifici si la sofer conexiunile de la airbag, exista posibilitatea ca eroarea sa fie de acolo.
Bafta!
Salutare... am intarziat sa-ti descriu problema deoarece am fost plecat de sarbatori si nu am mai stat pe net..
Oricum.. ti-am zis ca dupa ce am deconectat bateria mi-au ramas aprinse pe bord ledurile de la servo+presiune pneuri + ESP .. am facut cum mi-ai zis (am dat volanul max stanga- max dreapta) si dupa ce am rulat 500m s-au stins si totul a fost ok. Problema cu martorul airbag cred ca a fost de la mufa scaunului soferului. Eu aveam mufa de la scaun pasager taiata iar la scaunul sofer originalul... Am fost joia trecuta la SEAT si mi-au taiat mufa de la scaunul soferului/ resetat eroarea... si vad ca nu a mai aparut nimic...:) Bine am rulat cam 1000Km doar desi la doar o simpla resetare nu rezista mai mult de 200-300Km.. sper ca aia sa fi fost problema si ca am rezolvat-o.
Acum am o noua intrebare :)... vreaus a schimb saptamana viitoare lichidul de frana si vreau sa te intreb daca e necesar o anumita pompa mai speciala pentru asta... sau daca mi se poate defecta sistemul ABS si ESP de la asa ceva... Nu vreau sa merg la service SEAT pentru ca am avut niste experiente nasoale cu ei... la 3 service-uri "autorizate" diferite in 3 orase diferite... Asa ca vreau sa merg la un shop mai de "cartier" ca sa zic asa...
Merci mult,
Doru
Leon 1P 1.6 102CP
TM 83 VRD
23 Apr 2009, 16:17
Doru, nu stiu ce sa zic...Cred ca daca mergi la cineva care stie ce face si ai lichidul de frana potrivit (DOT 4, parca) nu o sa existe probleme.
Da' de ce vrei sa schimbi lichidul? Cati km ai cu masina?
23 Apr 2009, 16:18
Malaciuca scrie:
Si astea cat dau adunate? Mai putin cele scrise cu verde...alea sunt pt. cornering light.
Daca le iei de la PBV 2 ai 10 % discount ca membru clubseat.
Malaciuca
23 Apr 2009, 16:30
Cam scump totusi.
Cred ca ma orientez spre Becuri Simple cu installatie.
Duce pana la 1000 Mil maxim :)
Oricum recuperam TVA pe toate alea si 10% ca membru ClubSeat.
Dar e cam scump si ca sa stau sa le iau 1 dupa altu pana le am pe toate mai dureaza. Sa nu zic de tancul de hartii care se acumuleaza.
Malaciuca
23 Apr 2009, 16:37
Chiar acum vroiam sa mai scriu un post..
Le-am adunat eu si sunt cam pe la 7000 de lei.
pt. xenon OEM fara cornering light ai nevoie doar de astea (am incurcat piesele in prima faza)
Cover cap
Gas discharge bulb
Halogen bulb H1
Snap nut
Control Unit for automatic range control
In plus mai poti incerca pe la dezmebrari. Preturile nu trec de 50 % din pretul nou.
Malaciuca
23 Apr 2009, 16:45
Plus farurile ;)
Deci e clar. Oricum ms de ajutor si sper sa reusesti :)
Malaciuca.
verdesdoru
24 Apr 2009, 08:55
Cu masina am 40.000Km.. dar e de peste 2 ani... Din cate am inteles (asta scrie si-n programul service) trebuie schimbat la 2 ani indiferent de numarul de km. Mi-am cumparat 1L de Castrol Response DOT4... Avand in vedere ca nu e o operatie costisitoare ma gandeam ca merita schimbat... atata numa ca nu stiu exact daca in procesul de schimbare imi poate afect cumva senzorii si mecanismul de ABS si ESP... in mod normal nu tare ar trebui... am sa mai intreb la service oricum inainte de a face schimbarea... Este in TM ceva service PROMOTOR... ce se lauda ca au super echipamente... inca nu am fost la ei dar as putea sa le scriu un mail sa vad ce zic...
Merci oricum
Leon 1P 1.6 102CP
TM 83 VRD
eddy_wtx
LowRider
24 Apr 2009, 09:01
verdesdoru scrie:
Merci oricum
Iti recomand cu caldura PROMotor`ul la orice operatiune. Nici nu sunt scumpi, si sunt profesionisti, cu echipamente la fel de profesioniste :D
24 Apr 2009, 11:19
Malaciuca scrie:
Plus farurile ;)
Pai farurile sunt primele doua item-uri.. "Halogen twin headlight unit for gas discharge bulb left
Restul sunt controlere si unitati de comanda plus becuri etc.
Deci cu totul ar fi cam 6000-7000 de lei. E scump, intr-adevar. Regret enorm ca nu mai am asa ceva pe masina :(
Malaciuca
24 Apr 2009, 15:55
Malaciuca scrie:
Plus farurile ;)
Da de ce unu e mai scump cu 400 lei? :banghead:
In fine, e scump ce e drept dar merita. o sa ma mai gandesc la asta si daca e sa montez, presimt ca-o sa fac un drum pana la Sibiu :bounce:
Malaciuca.
24 Apr 2009, 16:05
Asa e, chiar merita. Chiar daca nu sunt AFS (cu cornering light).
Te astept cu cea mai mare placere :) . Totusi, anunta-ma din timp pt. ca mai sunt cateva cablaje ce trebuie cumparate si modificate.
Bafta!
  • 11
  • 12
  • 13
  • 14
  • 15
  • 146
