nakano
10 Aug 2012, 15:36
Salut Cosmin,
Sti cumva daca butonul de avarie (cu totul,ca doar capacul nu se gaseste separat :( ) de la leon FL se potriveste si la leon? Imi place cel de pe facelift si ...
Merci!
11 Aug 2012, 14:53
Da, se potrivestebutonul de la facelift
dragos.serban
Localitate: Bucuresti,Iuliu Maniu
16 Aug 2012, 20:46
Salut, am facut si eu o scanare si am urmatoarele coduri de eroare, problema este ca buzzer-ul de la senzorii de parcare nu mai functioneaza. Mersi
VCDS Version: Beta 11.3.0
Data version: 20110801
Wednesday,15,August,2012,14:07:44:10074
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72 76
VIN: VSSZZZ5PZ5R004413 Mileage: 62700km/38959miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: Malfunction 0010
Address 56: Radio Labels: 1K0-035-1xx-56.lbl
Part No: 5P1 035 152
Component: Radio BNO 0029
Coding: 0020402
Shop #: WSC 06403 785 00200
VCID: E6C732ABAD43
1 Fault Found:
00856 - Radio Antenna
011 - Open Circuit
Address 76: Park Assist Labels: 1K0-919-283.lbl
Part No: 5P0 919 283
Component: 05 Einparkhilfe 0101
Shop #: WSC 00000 000 00000
VCID: F5E565E7E0E5
1 Fault Found:
01543 - Parking Aid Warning Chime (H15)
002 - Lower Limit Exceeded
Seat Altea 2.0 FSI
17 Aug 2012, 08:15
verifica buzzerul de la senzori. uita-te in MB, vezi ce valori sunt acolo
nakano
24 Aug 2012, 10:08
Salut Cosmin, mai revin si eu cu o intrebare. Cum se face calibrarea speedo-ului pt. a arata o viteza cat mai exacta cu cea reala (a gps-ului de ex.) ?
Am vazut aici
[youtube]http://www.youtube.com/watch?v=c0GbLu0xVKE[/youtube]
(si in mai multe locuri) deci de putut pare ca se poate.
Multumesc!
Ultima oară modificat 24 Aug 2012, 12:55 de către Cosmin, modificat 1 dată în total.
Motiv: YT embedded
24 Aug 2012, 12:56
Pe instruments, distance impluse number. Trebuie sa iei in considerare si diametrul jantelor.
kmihai
Localitate: TIMISOARA
26 Aug 2012, 20:42
vreau sa-mi pun carligul de remorcare pe masina si am observat ca sunt mai mutle kit-uri electrice,adica sunt 2 modele.
unul pt preechipare care se leaga in partea din spate si unul pt cele fara preechipare la care se trag firele pana in fata se desfac mufe se muta pini (multa tiganeala).intrebarea este cum pot sa aflu daca masina mea are preechipare pt carlig de remorcare?
mersi
tot timpul am "admirat" oamenii mici cu ego-uri mari...grav e cand vaca care s-a suit in copac uita de unde a plecat.
27 Aug 2012, 13:38
fie te uiti pe codurile PR de pe stickerul din portbagaj, fie te uiti sub masina sa vezi daca ai vreun conector acolo.
boditza
27 Aug 2012, 15:03
Cosmin stii cumva care sunt exact diferentele intre diferitele versiuni ale navigatiei rns 510? Am vazut incepand cu versiunea B care e mai atractiva la pret pana la H. De ce as lua H si nu B in fara de faptul ca este mai veche cea din urma, dar diferenta de pret este de peste 150euro. Se pot face update la firmware-uri la ele?
kmihai
27 Aug 2012, 15:07
http://www3.westfalia.de/shops/autozube ... _m_vor.htm
asta cica este pt masini care au preechipare.
poti sa-mi detailezi unde anume este stikerul ala si ce anume ar trebui sa vad pe el in cazul in care are preechipare?
mersi
27 Aug 2012, 16:33
Diferenţe între diversele versiuni sunt multe. Unele versiuni de firmware suportă anumite funcţii, altele nu. De poate face upgrade de firmware,însă depinde şi ce versiune hw are unitatea. O să detaliez când o sa am ceva timp.
Mihai,e un sticker lipit pe prima pagină a caietului de service sau din mocheta din portbagaj. Fa o poza şi pune-o aici. Însă mai mult că sigur nu ai preechipare.
boditza
27 Aug 2012, 17:07
Chiar astept sa imi spui si mie diferentele.. pe net nu prea am gasit mare lucru
kmihai
27 Aug 2012, 18:57
Cosmin scrie:
uite stickerul
da-mi o veste buna ca ar fi preechipata :) nu de alta dar nu imi este tot una 200 sau 86euro..
si daca nu are preechipare, se poate lega doar in spate fara sa trag fire pana in fata?
uite aici cam despre ce este vb la cablaje
http://www.westfalia-automotive.de/index.php?id=54&L=1
mersi again.
28 Aug 2012, 09:09
Mihai, nu ai preechipare. Codul PR pt. preechipare e NH1.
Ai nevoie de urmatoarele piese (vezi imaginea), plus cablaj. Cablajul NU ai cum sa il legi doar in spate, sunt conexiuni la centrala electrica (sub bord, in partea stanga). Altfel masina nu va sti sa aprinda stopurile (plus celelalte becuri) de la remorca.
Diferentele intre diversele variante de RNS 510.
Asa, la prima strigare si pe scurt:
- versiunile A, B, C au HD de 30g, cele dupa D au de 40 (cu unele exceptii). Partitiile de muzca, harti si POI variaza.
- de la versiunea C, displayul e LED
- doar firmware peste 2xxx stie voice control, afisaj climatronic..
- plus alte mici mizerii nesemnificative.
Chestiile aste sunt valabile pt. RNS 510 cu brand VW si Skoda.
RNS 510 branded Seat (Seat Media System) exista doar versiunea A, cu ultimul firmware 1026. NU au mai dezvoltat noi versiuni pt. Seat, pt ca RNS 510 pe Seat a fost abandonat. S-a pus doar intre 2008 si 2009. Insa cel de Seat e super ok, nu trebuie taiat din nervurile interioare din bord pt. a fi montat la Leon / Altea. Vezi ca am unul la vanzare :tongue
boditza
28 Aug 2012, 14:17
Stiu ca ai de vanzare.. urmaresc posturile tale ca sunt f multe lucruri care le vreau ;) insa e vorba de bani in cazul meu.. Am gasit la 399eur rns 510 versiunea B din care scade pretul navigatiei mele rns 300 ca accepta schimb. Dar nu stiam ca trebuie taiat pe acolo daca il montez la mine, m-am gandit ca e plug&play. Ai cumva idee car ar costa can-gateway-ul care sa suporte rns-ul? De demontat se face pe la stergatoare sau pe sub coloana volanului cum spune in elsa? Codarea gateway-ului se poate face si cu o clona de vcds?
p.s. cat costa un bord maxidot de diesel pt pre-facelift la tine?
pps firmware-ul nu se poate actualiza la rns 510 non-seat?
