  • 92
  • 93
  • 94
  • 95
  • 96
  • 146
samson
28 Oct 2011, 08:19
Dupa amiaza ai log-ul, merci mult
samson
28 Oct 2011, 19:00
Si scanarea
VCDS Version: Beta 812.4
Data version: 20090214
Sunday,01,March,2009,18:39:28:26365
Chassis Type: 1K0
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72 76 7D
VIN: VSSZZZ5PZ5R030913 Mileage: 147620km/91726miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
62-Door,Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: OK 0000
7D-Aux. Heat -- Status: OK 0000
Address 01: Engine Labels: 03G-906-016-BKD.lbl
Part No SW: 03G 906 016 HM HW: 028 101 195 0
Component: R4 2,0L EDC G200AG 7000
Revision: 12345678 Serial number: SEZ7Z0D2650583
Coding: 0050078
Shop #: WSC 66565 257 00032
4 Faults Found
16611 - Throttle Pedal Position Sensor (G79): Signal too Low
P0227 - 000 - - - Intermittent
Freeze Frame:
RPM: 1323 /min
Torque: 0.0 Nm
Speed: 42.0 km/h
Load: 0.0 %
Voltage: 14.44 V
Bin. Bits: 00001000
Torque: 160.0 Nm
Bin. Bits: 0 01 0
16610 - Throttle Pedal Position Sensor (G79): Implausible Signal
P0226 - 000 - - - Intermittent
Freeze Frame:
RPM: 1386 /min
Torque: 34.0 Nm
Speed: 57.0 km/h
Load: 12.5 %
Voltage: 14.21 V
Bin. Bits: 00001000
Voltage: 1.216 V
Voltage: 0.760 V
18104 - Powertrain Data Bus: Implausible Message from Steering Column Controller
P1696 - 000 - - - Intermittent
Freeze Frame:
RPM: 0 /min
Torque: 88.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 13.07 V
Bin. Bits: 00101100
Bin. Bits: 11000000
(no units): 4.0
Readiness: 0 0 0 0 0
Address 02: Auto Trans Labels: 02E-300-0xx.lbl
Part No SW: 02E 300 041 HW: 02E 927 770 AD
Component: GSG DSG 041 0814
Revision: 00004010 Serial number: 00000408060355
Coding: 0000020
Shop #: WSC 06402 785 00200
No fault code found.
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No: 1K0 907 379 K
Component: ESP FRONT MK60 0103
Coding: 0023282
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No: 5P0 907 044 C
Component: ClimatronicPQ35 004 0202
Shop #: WSC 00000 000 00000
1 Fault Found
01274 - Air Flow Flap Positioning Motor (V71)
Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
Part No SW: 1K0 937 049 T HW: 1K0 937 049 T*
Component: Bordnetz-SG 1.0 H29 0704
Revision: 00029000 Serial number: 00000001283578
Coding: A18A8F2700041000001E00000000000000
Part No: 5P0 955 119 A
Component: Wischer SE359 012 0401
Coding: 00056272
Shop #: WSC 00000
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 H HW: 1K0 909 605 H
Component: S3 AIRBAG VW8 023 0700
Revision: 06023000 Serial number: 00385D0J9TNN
Coding: 0021299
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 B HW: 1K0 953 549 B
Component: Lenksäulenmodul 013 0010
Coding: 0012042
Shop #: WSC 40410 188 01577
Part No: XXXXXXXXXXX
Component: Lenkradmodul 004 0060
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No: 5P0 920 822 E
Component: KOMBIINSTRUMENT VO3 1056
Coding: 0000101
Shop #: WSC 10176 428 52237
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 C HW: 1K0 907 951
Component: Gateway H08 0080
Revision: 08 Serial number: 26001047090F17
Coding: 3F3F0F40078202
Address 25: Immobilizer Labels: 1K0-920-xxx-25.lbl
Component: IMMO 1056
Shop #: WSC 89328 120 85524
Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX1.lbl
Part No: 1T0 959 701 A
Component: Tuersteuergeraet 09 0139
Coding: 0000048
Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
Part No: 1K1 909 144 G
Component: EPS_ZFLS Kl.13 1401
Address 46: Central Conv. Labels: 1K0-959-433-MIN.clb
Part No: 1K0 959 433 BL
Component: 01 KSG 0301
Coding: 99C0009C2D290505488F090000
Component: Sounder n.mounted
Component: NGS n.mounted
Component: IRUE n.mounted
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX1.lbl
Part No: 1T0 959 702 A
Coding: 0000048
Address 56: Radio Labels: 1K0-035-1xx-56.lbl
Part No: 5P1 035 152
Component: Radio BNO 0035
Coding: 0000400
2 Faults Found
01044 - Control Module Incorrectly Coded
00856 - Radio Antenna
011 - Open Circuit
Address 62: Door,Rear Left Labels: 1K0-959-703-GEN1.lbl
Part No: 1K0 959 703 B
Component: Tuersteuergeraet 06 0216
Coding: 0000016
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN1.lbl
Part No: 1K0 959 704 B
Coding: 0000016
Address 76: Park Assist Labels: 1K0-919-283.lbl
Part No: 5P0 919 283
Component: 05 Einparkhilfe 0101
Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
Part No SW: 1K0 963 235 E HW: 1K0 963 235 E
Component: PTC-Element 0404
Revision: 00800000 Serial number:
cosminidis
29 Oct 2011, 11:53
Cosmin, Samson:
Oare la schimbarea pedalei nu trebuie refacut acel Throttle Body Alignment? Poate asta sa fie problema lui samson?
http://www.ross-tech.com/vag-com/cars/throttlebody.html
http://wiki.ross-tech.com/wiki/index.php/Throttle_Body_Alignment_(TBA)
31 Oct 2011, 19:57
There are certain test conditions that must be met before doing a TBA:
No DTC's in the Engine Controller
Ori el are deja DTC la ECU. Si inca o ..."chestie" esentiala: adaptarea TB se face la benzinare, nu la diesele. La diesele adaptezi EGR-ul doar.
samson
04 Noi 2011, 09:25
Cosmin, ai gasit vreo rezolvare la problema mea?
04 Noi 2011, 10:25
DIn pacate nu stiu care ar putea fi problema. Nu am documentatia pt. codurile alea
Cruise controlul functioneaza? Ca am vazut un DTC si in legatura cu J527
samson
04 Noi 2011, 11:57
Mai prins..... Mai face si ala figuri cand il apuca
adi_repulse
Localitate: Hamburg
22 Noi 2011, 12:36
Cosmin am si eu o intrebare... tocmai ce mi-a zis un prieten ca daca vreau sa imi pun pe masina kitul sutomat de lumini si ploaie, pe langa sensorul kitului ar trebui sa am si ceva senzori speciali pe parbriz? si ca ar fi un parbriz special creat pt senzori... is it true? si daca nu unde trebuie montat acel senzor, mersi
23 Noi 2011, 09:31
Prostii.
Intr-adevar exista doua tipuri de parbrize, unul cu marcaje pt. senzorul de lumina / ploaie si unul standard, fara. (fiecare dintre cele doua versiuni exista in varianta cu incalzire laterala sau fara..Ma rog..povesti )
Insa senzorul se poate monta si pe parbrizul normal, singura diferenta e ca nu o sa ai marcajul exact pt. pozitia senzorului.
Piesele necesare pt. montarea senzorului de lumina sunt urmatoarele (numerotate in imaginea de mai jos):
1. clema de prindere. Clema asta vine standard pe parbrizul marcat pt. senzor de ploaie / lumina. Pe parbrizul standard trebuiem cumparata de la dealer sau dezmembrari.
2. clema de fixare . Are rolul de a apasa folia de gel pe suprafata parbrizului, ca sa nu existe perne de aer intre suprafata senzorului si parbriz.
3. senzorul optic. Toata lumea stie ce face piesa asta.
4. ornament pt. interior . Acopera clemele si cablajul.
Din poza lipseste folia de gel care se pune intre senzor si parbriz.
Bineinteles, e nevoie de refacerea legaturilor electrice si recodare / activare cu VCDS.
In plus, pt. a functiona si iluminarea automata (aprinderea automata a farurilor cand e noapte afara) mai e nevoie de comutator de lumini cu functia AUTO. Fara comutatorul asta, va functiona doar stergerea automata a parbrizului (pornirea automata a stergatoarelor) atunci cand senzorul detecteaza apa pe parbriz. Asa arata comutatorul..
Spor la treaba! :)
23 Noi 2011, 09:43
Pt. Gamer..Ete punctele de masa in imaginile de mai jos..
O sa caut niste imagini de o calitate mai buna.
ImaginexImaginexImagine
adi_repulse
Localitate: Hamburg
23 Noi 2011, 10:31
sa ma risc sa imi faca cei de la reprezentanta recodarea? sau astia nu se ocupa cu asa ceva?
24 Noi 2011, 09:06
Gamer, chill.. Anytime. Spor la treaba..:)
Adi, recodarea e chiar o chestie minora..Teoretic la dealer ar trebui sa stie ce si cum..Insa pana acolo mai e de munca..Asta daca ai toate piesele necesare..
Trebuie desfacut plafonul (partea din fata), fixat senzorul (initial suportul, lasat 24 de ore sa se usuce adezivul - asta daca nu ai parbriz cu clema pt. senzor), refacut cablajul (ai nevoie de repair wires, conectori etc), facute legaturile electrice...Asta e bataie de cap.. recodarea se face in fix 12 secunde..
samson
26 Noi 2011, 10:38
Cosmin, spune-mi si mie daca stii ce reprezinta pinii la fiecare din cele doua mufe, de bixenon OEM(14 pini) si clasica cu oglinda(10 pini). Vreau sa fac adaptarea la motorase si poate si la "lamela" de la faza lunga.
please help
27 Noi 2011, 10:43
Pot sa iti spun doar unde sunt legati (adica de unde vin firele care intra in conctor) si sa iti prezint diferentele intre bixeonon OEM (cu AFS) si halogen. Insa doar saptamana viitoare, am diagrama la servici.
Legaturile interne (din far) din pacate nu pot sa le detaliez pt. ca nu stiu.
Lasa-mi si un PM cu nr. tau de telefon, te rog.
  • 92
  • 93
  • 94
  • 95
  • 96
  • 146
