  • 80
  • 81
  • 82
  • 83
  • 84
  • 144
dzaraider
ClubSEAT Team
01 Apr 2011, 00:42
Cosmin, am reusit sa scot un log complet...problema era cablul cu tot cu driver(nu era facut sa mearga pe windows 7 x64)...dar am reusit sa il schimb si acum totul merge cum trebuie dar tot imi da mesajul ala ciudat cand incerc sa sterg erorile de la Aux heating, ti-am atasat mai jos logu:
Thursday,31,March,2011,21:54:12:60804
VCDS Version: Release 10.6.0 (x64)
Data version: 20100630
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 7D
VIN: VSSZZZ1PZ7R040085 Mileage: 73310km/45552miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
7D-Aux. Heat -- Status: Malfunction 0010
Address 01: Engine Labels: 03G-906-016-BKC.lbl
Part No SW: 03G 906 021 LK HW: 03G 906 021 AN
Component: R4 1,9L EDC G000SG 9249
Revision: --H05--- Serial number: SEZ7Z0F3589565
Coding: 0050071
Shop #: WSC 06441 785 00200
VCID: 73EE5A3A6BDD
No fault code found.
Readiness: 0 0 0 0 0
Address 03: ABS Brakes Labels: 1K0-907-379-MK70.lbl
Part No: 1K0 907 379 P
Component: ASR FRONT MK70 0105
Coding: 0000641
VCID: 3F86C60A1715
Address 08: Auto HVAC Labels: 1K0-820-047.lbl
Part No: 5P0 820 047 K
Component: Climatic PQ35 012 0505
Shop #: WSC 00000 000 00000
VCID: 356AA4222529
Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 E HW: 3C0 937 049 E
Component: Bordnetz-SG H37 1002
Revision: 00H37000 Serial number: 00000004387878
Coding: A9880F2F00041000321D00000000000000317F075C
VCID: 2B5E825AF36D
Part No: 1P0 955 119 A
Component: Wischer SE350 012 0403
Coding: 00056272
Shop #: WSC 06441
Address 15: Airbags Labels: 3C0-909-605.lbl
Part No SW: 3C0 909 605 L HW: 3C0 909 605 L
Component: R2 AIRBAG VW8 028 2522
Revision: 10028000 Serial number: 003B0PKH1P5L
Coding: 0021042
VCID: 2F66964AC775
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 BC HW: 1K0 953 549 BC
Component: Lenksäulenmodul 636 0070
Coding: 0000042
VCID: 74EC59266ED3
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No: 1P0 920 823 G
Component: KOMBIINSTRUMENT VO3 0422
Coding: 0000101
Shop #: WSC 10176 428 52237
VCID: 30649536DA4B
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 H HW: 1K0 907 951
Component: J533__Gateway H12 0150
Revision: H12 Serial number: 310010690188E2
Coding: 3D0F0B4007000202
VCID: 2C5C8146F663
Address 25: Immobilizer Labels: 1K0-920-xxx-25.lbl
Component: IMMO VO3 0422
VCID: 30649536DA4B
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
Part No SW: 1T0 959 701 F HW: 1K0 959 793 L
Component: J386 TUER-SG FT 1123
Revision: 12006001 Serial number: 00000111768802
Coding: 0000048
VCID: 3A70B71E0C37
Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
Part No: 1K1 909 144 L
Component: EPS_ZFLS Kl.077 H07 1806
VCID: 346C99262E53
Address 46: Central Conv. Labels: 1K0-959-433-MIN.clb
Part No: 1K0 959 433 AK
Component: KSG 0401
Coding: 19C000CC7F000505484B012004CC
VCID: 79F2681249B1
Component: Sounder n.mounted
Component: NGS n.mounted
Component: IRUE n.mounted
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 1T0 959 702 F HW: 1K0 959 792 L
Component: J387 TUER-SG BT 1123
Revision: 12006001 Serial number: 00000529168726
Coding: 0000048
VCID: 3B7EB21A030D
Address 56: Radio Labels: 1K0-035-1xx-56.lbl
Part No: 1P1 035 186 B
Component: Radio BVX 0006
Coding: 0020414
VCID: 2B5E825AF36D
Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
Part No SW: 1K0 963 235 E HW: 1K0 963 235 E
Component: PTC-Element 0404
Revision: 00800000 Serial number:
VCID: 2D5A8C42CD79
2 Faults Found:
00361 - Heater Element for Auxiliary Heater (Z35)
014 - Defective
01299 - Diagnostic Interface for Data Bus (J533)
005 - No or Incorrect Basic Setting / Adaptation
01 Apr 2011, 08:29
E clar o problema cu softul. De aici DTC-uri diferite pe aceeasi adresa (sunt convins ca nu ai navigatie cu CD ROM separat :) )
Daca datele sunt corecte, atunci se pare ca e o problema cu radiatorul de la incalzirea auxiliara. Totusi, vad ca WSC e zero. Incearca sa introduci manual valorile pt. Importer Number si Work Shop Code Number. Pune unele aleatorii. Apoi incearca sa stergi eroarea.
De obicei erorile de pe adresa 7D nu prea pot fi sterse, insa incearca totusi.
Verifica si MVB (valorile exprimate) si vezi daca incalzirea functioneaza. Ca si ultima solutie, va trebui sa schimbi radiatorul ala. Problema e ca trebuie sa dai plansa de bord jos, radiatorul pt. incalzire auxiliara fiind situat in airboxul de la climatizare.
Ovidiu, in imaginea postata de mine e o masina care NUare computer de bord. Deci daca ai computer de bord, NU poti avea vizualizarea aia.
crysu, foloseste ca referinta imaginea asta. E extrem de sugestiva. Bafta cu vopsitul !(eu sunt reticent la rezistenta vopselei pe plasticul ala, insa e alegerea ta)
dzaraider
ClubSEAT Team
01 Apr 2011, 09:10
Dap, asa e nu am navigatie cu CD-ROM separat :D.
O sa incerc ce mi-ai sugerat, daca nu merge asta e...service scrie pe mine.
Mersi mult pentru rabdare si ajutor. Sa auzim numai de bine :hi
crysu
the yellow one
Localitate: Bucuresti (ex Craiova)
01 Apr 2011, 10:42
Cosmin scrie:
Ma gandesc ca daca il slefuiesc bine si ii aplic o anume substanta (care acum nu imi vine in minte, care face ca vopseaua sa adere mai bine la plastic) o sa iasa bine, daca nu asta este ... cineva trebuie sa incerce.
Actual: Seat Leon 1P 1.6
Poate vreodata: Altea 4 Freetrack
01 Apr 2011, 15:38
Primer? La asta te referi?
Ce sa zic..poate o sa reziste daca e vopsit bine..
Succes!
crysu
the yellow one
04 Apr 2011, 15:32
Cosmin ... exista vreo diferenta intre MP3-urile care se gasesc pe LEON cu si fara USB. Stiu ca Leon-ul 1P are portul de usb sub scaunul pasagerului daca nu ma insel. Exista vreo diferenta intre cele doua MP3 playere ? ... se poate adapta conexiunea USB la unul care nu a venit din fabrica cu port USB ?
Multumesc
05 Apr 2011, 08:01
Nu e nici o diferenta. Playerele sunt identice.
Da, se poate monta interfata USB / Ipod originala sub scaunul pasagerului.
Ai nevoie de interfata, cablaj si conector (8 pini). Se leaga la conectorul quad al playerului.
crysu
the yellow one
05 Apr 2011, 10:15
Cosmin scrie:
probabil te-am stresat destul ... dar inca ceva ... ai cumva niste coduri pentru operatiunea asta
multumesc
05 Apr 2011, 10:25
Stai linistit, nu e nici un stres. Sunt aici din placere / pasiune :)
La ce coduri te referi? La codurile pieselor?
Le am, insa trebuie sa iti tai elanul pt. ca daca intentionezi sa le cumperi de la dealer sunt extrem de scumpe..Cele mai bune sanse le ai la dezmembrari, insa interfetele pt. Seat sunt destul de rare.
Poti cumpara in schimb ca si kit o interfata non-OEM (care e si mai ieftina) si face acelasi lucru. Emuleaza o magazie de CD-uri, ca si interfata USB / IPOD originala (de sub scaun).
Nici una, nici alta nu suporta id3 tags (nu o sa apara pe displayul playerului informatii despre artist / piesa).
Incepand cu modelul FL, s-a renuntat la interfata de sub scaun si s-a montat MDI (in fata butonului de la luminile de avarie). Asta e mai desteapta, stie id3. Insa nu stiu daca e compatibila cu playerul pe care il ai tu pe masina
bertzi43
B-82-AJS
05 Apr 2011, 13:52
:hi :hi salut cosmin,ma poti ajuta cu niste informatii pt montajul unor oglinzi electrice pe un seat leon 1m varianta stella,oglinzile le-am achizitionat........daca ma poti ajuta cu codurile cablajelor necesare,multumesc
dzaraider
ClubSEAT Team
05 Apr 2011, 14:26
salut cosmin, am verificat MVB cum mi-ai spus si incalzirea se pare ca functioneaza are output de 600W la 25A, insa eroarea (00361 - Heater Element for Auxiliary Heater (Z35)
014 - Defective) tot acolo e. singura diferenta e ca a disparut eroarea aia aberanta cu navigatia pe CD-ROM. Poti sa imi dai te rog un exemplu de coduri care asi putea sa le introduc pentru Importer Number si Work Shop Code Number.
Mersi si scuze ca te stresez da m-am interesat de amaratul ala de radiator si e in jur de 1300 RON.
dzaraider
ClubSEAT Team
05 Apr 2011, 14:39
Sorry pentru inca un post Cosmin...ai idee cumva care e security accesc code-ul pentru adresa 7D?
crysu
the yellow one
05 Apr 2011, 18:00
Cosmin scrie:
ma gandesc ca decat sa le cumpar pe astea mai bine iau un player aftermarket si rezolv "problema"
06 Apr 2011, 08:21
Bertzi, pt. oglinzi electrice ai nevoie si de butonul de actionare (din usa soferului) cu trimul (ornamentul in care e incastrat), de unitate electronica din usa soferului care sa suporte oglinzi electrice, de cablajele din usile fata cu conector pt. oglinzi (sau de adaugarea conectorului pt. oglinzi si refacerea legaturilor electrice).
E mai simplu daca ai cumpara cablajele cu totul, insa la dealer sunt enorm de scumpe. Poate gasesti la dezmebrari o masina care a avut asa ceva din fabrica si le iei cu totul.
O sa iti detaliez cum sa faci legaturile electrice sau poti lua legatura cu colegul dany19940 memberlist.php?mode=viewprofile&u=508 . Pe el l-am ajutat intr-o problema similara si i-am trimis diagrama de la intregul sistem convenience (pe care din pacate momentan nu o mai am)
dzaraider, foloseste 123 si 12345. NU stiu SC pt. 7D, insa la ce iti trebuie?
Poti cauta radiatorul la dezmebrari, merge si de pe Golf 1K, Octavia 1Z. Altea 5P etc.
crysu, e si asta o solutie, insa personal cred ca, desi un player aftermerket de multe ori are performante mai bune decat playerul original, montarea unei asemenea unitati strica tot aspectul plansei de bord. Playerele AM in cele mai multe cazuri au tot felul de lumini si luminite care nu "se pupa" nicicum cu celalalte elemente.
Nu mai vorbim de faptul ca un player AM highend e mult mai scump decat un emulator digital de cd changer.
Parerea mea :)
dzaraider
ClubSEAT Team
06 Apr 2011, 14:23
mersi Cosmin....mi-a spus cineva care are (teoretic) mai multa experienta ca mine la vcds ca daca are SC poate sa intre in coding si sa rescrie coding-ul cu unu de pe un golf 5 cu acelasi motor ca al meu adica seria BKC.
Numai bine.
  • 80
  • 81
  • 82
  • 83
  • 84
  • 144
