bounceone
Probleme seat cordoba
03 Iun 2014, 13:17
Buna ziua!
Am un Seat Cordoba, 1,4l benzina si am urmatoarea problema. Dau la cheie, masina da sa pornesca si dupa 2 secunde se opreste. Efectiv nu reusesc sa o pornesc. Am dus-o tractata la un service si mi-au zis ca nu este pe partea electrica ca am un dop undeva, dar nu gasim unde. Stie cineva ce ar putea fi?
Seat Cordoba 2007
1.4 16V 86 CP Rosu Emotion
doomduke
Re: Probleme seat cordoba
03 Iun 2014, 13:38
Incompetenti, schimba service-ul. Ce naiba vor sa zica cu "dop pe partea electrica" !!!
SEAT Ibiza Mk3 (Typ 6L)
Color LS5V Azul Lluvia
Engine specifications
03 Iun 2014, 15:33
postezi o copie a logului?
bounceone
04 Iun 2014, 19:28
Sal
Pina la urma cica ar fi calculatorul... naspa rau
Stie cineva cit costa unul nou, sau cit este unul second? Sau mai pot sa-l repar pe asta ?
Seat Cordoba 2007
04 Iun 2014, 20:19
Pai pune logul ala, sa vedem ce fault este. Cum de-a ajuns la concluzia asta meseriasul ?
bounceone
05 Iun 2014, 09:12
Sal
Asta este ce a iesit la diagnosticare
Wednesday,04,June,2014,11:47:20:13314
VCDS Version: Release 908.0
Control Module Part Number: 03C 906 024 H HW: 000 000 000 00
Component and/or Version: MARELLI 4HV 0118
Software Coding: 0000071
Work Shop Code: WSC 06402 785 00200
4 Faults Found:
18011 - Internal Control Module: Failed Self-Test
P1603 - 000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 1
Fault Frequency: 0
Reset counter: 0
Mileage: 0 km
Time Indication: 0
Date: 2000.01.01
Time: 00:00:00
Freeze Frame:
Bin. Bits: 00000000
Load: 0.0 %
Lambda: 0.0 %
Speed: 0.0 km/h
Temperature: 20.0°C
Absolute Pres.: 971.5 mbar
RPM: 0 /min
17763 - Cylinder 1 Ignition Circuit: Open Circuit
P1355 - 000 - - - Intermittent
Freeze Frame:
Fault Priority: 1
Fault Frequency: 0
Reset counter: 0
Mileage: 0 km
Time Indication: 0
Date: 2000.01.01
Time: 00:00:00
Freeze Frame:
Bin. Bits: 00000000
Load: 98.9 %
Lambda: 0.0 %
Speed: 0.0 km/h
Temperature: 19.0°C
Absolute Pres.: 989.4 mbar
RPM: 294 /min
16415 - Oxygen (Lambda) Sensor B1 S1: Heating Circuit: Short to Ground
P0031 - 000 - - - Intermittent
Freeze Frame:
Fault Priority: 1
Fault Frequency: 0
Reset counter: 0
Mileage: 0 km
Time Indication: 0
Date: 2000.01.01
Time: 00:00:00
Freeze Frame:
Bin. Bits: 00000000
Load: 98.9 %
Lambda: 0.0 %
Speed: 0.0 km/h
Temperature: 19.0°C
Absolute Pres.: 991.8 mbar
RPM: 239 /min
17071 - ECM Power Relay Control Circuit (J271): Short to Plus
P0687 - 000 - - - Intermittent
Freeze Frame:
Fault Priority: 1
Fault Frequency: 0
Reset counter: 0
Mileage: 0 km
Time Indication: 0
Date: 2000.01.01
Time: 00:00:00
Freeze Frame:
Bin. Bits: 00000000
Load: 0.0 %
Lambda: 0.0 %
Speed: 0.0 km/h
Temperature: 19.0°C
Absolute Pres.: 995.7 mbar
RPM: 0 /min
Daca stie cineva ceva, as aprecia mult ajutorul
multumesc
Seat Cordoba 2007
05 Iun 2014, 09:56
trebuia sa-l postezi pe tot, eu as verifica intai starea bateriei si a bornelor, cablurilor, conectorilor.
Bateria sa fie corect incarcata pe un redresor si apoi faci o diagnoza. :hi
05 Iun 2014, 10:45
Engine Control Module Power Relay Control Circuit High
Possible causes
- Weak battery- Low voltage while cranking
- Poor engine control module electrical connection
- Open or short engine control module circuit
- Failed Fuse
- Faulty relay
Posibil ECU sa nu fie alimentat cum trebuie si sa nu apuce sa-si faca self-test-ul cum trebuie. Deocamdata vad ca faultul respectiv e intermitent, ceea ce sugereaza un contact aiurea pe undeva sau chiar acel releu sa fie dus sau o masa imperfecta. Ce motor ai, ce an? Poate dau de ceva schema sa ma uit.
bounceone
05 Iun 2014, 14:15
Sal
Motor BXW an 2007
multumesc!
Seat Cordoba 2007
05 Iun 2014, 20:35
Daca ai vreun electronist, ar putea sa-si arunce un ochi in ECU sa afle cauza de iti da defectul cu releul - 17071. Cum se ataseaza un pdf pe site, ca n-am descoperit? Sau trebuie urcat pe alt site si se da linkul aici?
Sau da-mi o adresa de mail in pm sa-ti trimit o schema.
adikim
Localitate: barlad
25 Aug 2014, 12:14
Salutare!
Am cautat pe site dar nu am gasit unde sa postez in alta parte!
Am urmatoarea problema: se aude un zgomot de parca ar fi produs de un avion, dar dupa ce depasesc 40-50 km/ora indiferent ca masina este in viteza sau pe liber. Mentionez ca nu se aude ca un huruit ci ca si cum ar fi un zgomot facut de un cauciuc care in rulare s-ar freca de ceva.Am verificat rotile si nu imi atinge nici un cauciuc pe nicaieri. Insa daca in mers iau viraj dreapta chiar si foarte putin acel zgomot dispare(doar atat timp cat tin volanul virat).
Merci anticipat!
25 Aug 2014, 14:43
Rulment-fata !
adikim
Localitate: barlad
26 Aug 2014, 15:56
Merci!
Trebuie sa-mi fac timp sa ajung la mecanic!
Drumuri bune!
