grimarius
Localitate: Botosani
Re: Eroare VCDS
08 Dec 2014, 22:51
Am si eu urmatoarele coduri de eroare:
Monday, 08 December 2014, 22:21:11:0
VCDS-Lite Version: Release 1.0
Control Module Part Number: 6K0 906 034 D
Component and/or Version: MARELLI 4LV S152
Software Coding: 00001
Work Shop Code: WSC 00000
5 Faults Found:
16785 - EGR System: Insufficient Flow
P0401 -- 35-00 - -
17587 - Linear O2 Sensor; Pump Current: Short to Ground
P1179 -- 35-10 - - - Intermittent
16930 - Sensor 1 for Exhaust Temp Bank 1 (G235): Short to Plus
P0546 -- 35-00 - -
17602 - Fuel Pressure Regulator Valve (N276): Short to Plus
P1194 -- 35-10 - - - Intermittent
17618 - Cylinder Shut-Off; Intake Deactivation Valves: Short to Plus
P1210 -- 35-10 - - - Intermittent
Primele doua sunt mai vechi (egr nu am si sonda lamba a doua mai da rateuri).
Poate cineva sa le explice...si cam care ar fi cauza.
Cordoba 2002, motor AUA, 1,4 16v
grimarius
Re: Eroare VCDS
11 Dec 2014, 09:07
Nu sunt bune codurile, mi le fabrica interfata. Am scanat in alta parte si a gasit doar eroare la EGR si la sonda Lambda.
