gabrielgrz
Rog indrumare
14 Oct 2013, 15:03
In urma unei scanari de rutina a masinii am gasit urmatoarele erori:
Sunday,13,October,2013,19:34:27:37412
VCDS Version: Release 11.11.0
Data version: 20111111
Chassis Type: 6L - Seat Ibiza/Cordoba
Scan: 01 02 03 08 09 15 17 19 25 37 44 46 55 56
VIN: VSSZZZ6LZ3R075978 Mileage: 85720km/53263miles
Part No: 03E 906 033 D
Component: 1,2l/4V SIMOS3 00HS4650
Coding: 00031
Shop #: WSC 06402
VCID: 21439420ABD2F56
VSSZZZ6LZ3R075978 SEZ7Z0B1753229
4 Faults Found:
16554 - Fuel Trim; Bank 1
P0170 - 35-10 - Malfunction - Intermittent
16514 - Oxygen (Lambda) Sensor B1 S1
P0130 - 35-10 - Malfunction in Circuit - Intermittent
18047 - Accelerator Position Sensor 1/2 (G79/G185)
P1639 - 35-10 - Implausible Signal - Intermittent
17925 - Power Supply Relay for ECU (J271 or J363)
P1517 - 35-10 - Electrical Malfunction - Intermittent
Readiness: 0010 0001
Address 09: Cent. Elect. Labels: 6Qx-937-049-C.lbl
Part No: 6Q1 937 049 C
Component: 00 BN-SG. 1S33
Coding: 16396
Shop #: WSC 06402
VCID: 3B7F4648297EBF6
2 Faults Found:
01598 - Drive Battery Voltage
27-10 - Implausible Signal - Intermittent
07-10 - Signal too Low - Intermittent
Address 46: Central Conv. Labels: 6Q0-959-433.lbl
Part No: 6Q0 959 433 E
Component: 2J Komfortgerát 0002
Coding: 00066
Shop #: WSC 06402
VCID: 3D7B4850376AB16
Subsystem 1 - Part No: 6Q2959802A
Component: 2J Tõrsteuer.FS KLO 0001
Subsystem 2 - Part No: 6Q2959801A
Component: 2J Tõrsteuer.BF KLO 0001
3 Faults Found:
00928 - Locking Module for Central Locking; Front Driver Side (F220)
27-00 - Implausible Signal
00929 - Locking Module for Central Locking; Front Passenger Side (F221)
00933 - Electric Window Motor; Passenger Side (V148)
62-00 - No or Incorrect Adjustment
Va rog cateva sfaturi inspre rezolvarea problemelor.
Toata stima!
Re: Rog indrumare
14 Oct 2013, 16:27
Mai intai de toate, schimba bateria, sau asigurate de starea ei.
Exista testere computerizate in serviceuri care fac o diagnoza a bateriei .
Apoi reseteaza toate erorile, mergi putin cu masina , si probabil o sa ramana doar cele care chiar sunt defecte!
Parca mergi prea putin sau scurte drumuri cu masina?
Re: Rog indrumare
14 Oct 2013, 16:40
Mihai spune bine despre baterie. Majoritatea erorilor de acolo de la ea slaba apar. In plus, la partea de inchidere, ai lipituri reci in broaste. Procedura de remediere a tot fost dezbatuta pe forum.
gabrielgrz
Re: Rog indrumare
24 Oct 2013, 22:20
Ok domnilor, acum am reusit sa "dau" si eu de net,si-mi cer scuze ca am raspuns asa de greu, multumesc nmihai67, multumesc dany19940. Voi incerca cum ati spus, schimbatul baterie, sa vedem ce e atunci, dar, voi cauta si rezolvarea la problema cu lipiturile reci despre care ati scris. Intradevar nmihai67, in general, fac drumuri scurte, e de rau, e de bine?
Multumesc inca odata. Voi reveni.
Re: Rog indrumare
25 Oct 2013, 10:17
La drumuri scurte nu prea are timp sa se incarce bateria. Asta e o posibila cauza a slabirii ei. Problema e ca se poate sa fie pe duca din cauza asta. Mai pune-o si tu pe un redresor automat, nu home-made, ca nu stie sa limiteze sau chiar sa opreasca incarcarea cand bateria ajunge la capacitate optima.
gabrielgrz
Re: Rog indrumare
31 Oct 2013, 22:38
Ok dany19940, sambata voi incerca sa fac cum mai indrumat, voi vedea daca se rezolva ceva. Multumesc tare mult.
gabrielgrz
Re: Rog indrumare
07 Noi 2013, 17:33
Salut dany19940, salut nmihai67, salut tututor forumistilor. Se pare ca dupa ce am reincarcat bateria, am si pornirea mai usoara, si imi merge si inchiderea centralizata mai bine, inainte nu o puteam deschide din cheie, dar o puteam inchide, acum functioneaza asa cum ar trebui. O alta problema pe care am uitat sa o mentionez este problema functionarii alarmei, care este aftermarket, in ce sens? Se activeaza dar nu mai ţipa, decat daca lovesc masina foarte tare, iar inainte nu facea asa. Am incercat sa reglez sensibilitatea si degeaba. Ceva sfaturi?
Multumesc anticipat.
Re: Rog indrumare
07 Noi 2013, 23:47
Doar de la cel care a montat alarma...si nu e mai bine sa sune decat in situatie reala?
gabrielgrz
Re: Rog indrumare
08 Noi 2013, 15:41
Problema e ca nu mai am cum sa dau de cel care a montat alarma, si nici nu stiu daca suna in situatia reala, de aceea imi e putin teama.
Stima.
