Aurash
Localitate: Slobozia
Interpretare diagnoza.
04 Apr 2013, 16:34
Am facut recent o scanare a masinii si am depistat urmatoarea eroare
Address 08: Auto HVAC Labels: None
Part No: 6L0 820 043 B
Component: CLIMAtronic PQ24 0201
Shop #: WSC 00000 000 00000
VCID: 254B8030EFFA196
3 Faults Found:
00710 - Defroster Flap Positioning Motor (V107)
000 - - - Intermittent
01271 - Positioning Motor for Temperature Flap (V68)
00792 - A/C Pressure Switch (F129)
Stie cineva ce poate fi de vina?
Seat Cordoba 1,4 16v;74kw
Re: Interpretare diagnoza.
04 Apr 2013, 16:45
01271 - Positioning Motor for Temperature Flap (V68): Faulty
Possible Causes
Wiring/Connectors from/to Positioning Motor for Temperature Flap (V68) faulty
Positioning Motor for Temperature Flap (V68) blocked
Possible Solutions
Check Positioning Motor for Temperature Flap (V68)
See Measuring Value Blocks (MVB)
Perform Output Test
Perform Basic Setting
Check/Repair Wiring and Connectors
Possible Symptoms
A/C System not working
Possible Causes
A/C System Malfunctions
Over or insufficiently charged
Refrigerant System blockage
Insufficient Air Flow to Condensor and/or Engine Radiator
Wiring to/from A/C Pressure Switch (F129) faulty
Possible Solutions
Check A/C System for Malfunctions
Check Wiring to/from A/C Pressure Switch (F129)
Check A/C Pressure Switch (F129)
Aurash
04 Apr 2013, 16:52
Bun sa inteleg ca e comutatorul de inalta presiune climatizare o data..
si in legatura cu clapeta aia? ce trebuie luat?
04 Apr 2013, 20:21
Nu e comutator de inalta presiune, cel mai probabil nu ai cantitatea de freon necesara in instalatie. Erorile cu motorasele se rezolva prin scoaterea lor afara si curatarea potentiometrelor de pe ele. S-a tot vorbit pe forum despre ele, si de cele mai multe ori pe Ibiza/Cordoba parca.
Aurash
04 Apr 2013, 23:17
Multam. am pierderi de freon( in 2 luni e gol) si am sa fac o verificare sa vad unde pierde si sa remediez problema . deci e foarte posibil sa ai dreptate.
