FreeStyleDaNuTzU
Localitate: Dambovita,Pucioasa
I love you my toledo!!!
20 Ian 2013, 21:49
De curand am achizitionat si eu un dragalas Toledo si as vrea sa impartasesc enorma bucurie si cu voi. :cheers
Este vorba de un Seat Toledo 1.6 16v 77kw/105cp(cod motor AUS E4) fabricatie 2001
Iata cateva poze Astept niste pareri sincere! Multumesc:)
Imagine Imagine Imagine Imagine Imagine Imagine Imagine Imagine Imagine Imagine
Iata si codurile din cartea service:)
2C2 = Axial and vertical adjustable steering column (reinforced)
B0V = Component parts set, complying with vehicle type for the Netherlands various parts
C6E = Steel wheels 6J x 15 Offset 38
G0C = 5-speed manual transmission
H6S = Tires 195/65 R15 V
J1L = Battery 280 A (60 Ah)
D3H = 4-cylinder gas. engine 1.6 L/77 kW (16V)with multi-point injection Base engine is T27/TL0/TT0/TV5
Q1A = Standard front seats
1AC = Anti-lock brake system (ABS)
1G2 = Steel spare wheel with original equipment tires
2PX = Leather trimmed sports steering wheel
1NR = Wheel center cover
5RU = Right exterior mirror: convex (large viewing field)
5SL = Left exterior mirror: aspherical
T27 = 4-cylinder gasoline engine 1.6 L unit 036.L
0BC = Rear stabilizer
3U4 = Luggage compartment cover
0G3 = Gearshift linkage
8YE = Radio for comfort-class vehicle
8GD = Alternator 90A
8L3 = Roof antenna
1KP = Disc brakes, rear
1LQ = Front disc brakes with integrated adapter
G22 = Front shock absorption
4UE = Air bag for driver and front seat passenger
5X1 = Cab rear panel with lining
4R4 = Power windows with comfort operation andcircuit breaker
4K3 = Radio remote controlled central locking operated from inside and safe securing
N7C = Fabric seat covering
5TC = Without decorative inserts
8RM = 8 speakers (passive)
2JB = Standard bumpers
0AE = Front stabilizer
1JD = Rear shock absorption, basic design 2
L16 = Suspension range 16 installation control only, no requirement forecast
0YZ = Without determination of weight categoryfor rear axle
Seat Toledo 1.6.16v 2001 Cod AUS
viewtopic.php?f=40&t=14608&st=0&sk=t&sd=a
ciprian83
Zorro
Localitate: Hunedoara
Re: I love you my toledo!!!
20 Ian 2013, 21:54
Bine ai venit in ClubSeat . :cheers Foarte frumosa masina si intretinuta,sa o stapanesti sanatos si multa bafta iti doresc in continuare.
Audi A4 B7 2008. 1,9TDI
Ex-seat toledo 1,6 16V 2004
BV-69 MSY
Localitate: brasov
20 Ian 2013, 21:57
bun venit si din partea mea in CS :cheers !frumoasa masina!cat mai multi km fara incidente neplacute!!bafta
viewtopic.php?f=134&t=12679 leon 1M 1,6/16 valve/105 ponei/AUS
TuPeU
Localitate: Galati
20 Ian 2013, 21:58
frumoasa masina, sa o stapanesti sanatos si km multi fara probleme :D
FreeStyleDaNuTzU
20 Ian 2013, 21:58
Multumesc frumos! :hi
mususk266
20 Ian 2013, 22:04
bine ai venit, frumoasa masina, sa te bucuri de ea.
FreeStyleDaNuTzU
20 Ian 2013, 22:17
Am si eu o intrebare pentru cunoscatori la ce foloseste cele doua display-uri din mijlocul ceasurilor de bord la mine nu afiseaza nimic... am "citit" in carte (tot citit se numeste si cand te uiti la poze ca nu intelegi limba nu? :P ) ca ar fi unul dintre ele pentru a indica treapta de viteza cand masina este dotata cu o cutie automata sau pentru a afisa un meniu al cd-player -ului poate ma lumineaza si pe mine cineva daca le-as putea activa cumva sa apara ceva pe ele ar fi super:)) Multumesc anticipat. :bounce: :yah
20 Ian 2013, 22:25
Salutare si bun venit in club.
Frumoasa masina si intretinuta.ceva planuri de modificari???
in cele doua mici ferestre,prima la mine e nefunctionala,iar cea de a doua afiseaza volumul,track-ul,frecventa HU.
FreeStyleDaNuTzU
20 Ian 2013, 22:27
Vreau sa afiseze si la mine:(( am sistem audio original Aura cu magazie originala in torpedou :( se poate activa cumva:(
20 Ian 2013, 22:30
cred ca s-ar putea face.si la mine e tot echiparea OEM.
colegul Dany iti poate spune sigur.
20 Ian 2013, 22:31
Daca nu il ai acum, nu ai CE activa. Ti-ar trebui un modul ce vine bagat in bord acolo, plus cablajul de la el la AURA.
PS:Bine-ai venit pe forum. Masina ta e identica cum a fost a mea la inceput. :hi Multi Km fara incidente!
FreeStyleDaNuTzU
20 Ian 2013, 22:36
Display in sine eu cred ca exista acolo in ambele locuri pentru ca se vede ca si un diplay nu se vede negru ca la altele dar nu afiseaza nimic:(
20 Ian 2013, 22:39
Inca nu am vazut nici-o masina cu amble display-uri montate, deci nu ai cum sa le ai pe amandoua. Ce vezi tu...nu vezi bine.
20 Ian 2013, 22:42
Bun venit si sa-l stapanesti sanatos!!! :hi
Din poze mie mi se pare ca nu exista display-ul acolo, ci doar capacele de plastic negru care acopera zona.
Cel mai simplu, compara cum se vede in poza display-ul de la Aura si cum se vede acolo. Eu zic ca nu ai nici unul.
20 Ian 2013, 22:43
Dany,parca la Nicola Cristian vazusem amandoua afisajele functionale.cand avea HU Aura afisa pe primul display iar pe cel de jos era afisata temperatura.
