adragut
Coduri de eroare date de VCDS
18 Dec 2012, 13:46
Azi dupa ce am facut o verificare cu VAG Com-ul mi-au aparut urmatoarele erori:
Chassis Type: 1M - Seat Leon/Toledo
Scan: 01 02 03 08 15 17 19 22 35 36 37 46 56
VIN: VSSZZZ1MZ2R071252 Mileage: 150210km/93336miles
Part No: 036 906 034 CP
Component: MARELLI 4MV 4376
Coding: 00031
Shop #: WSC 06402
VCID: 62C1DB2CEE54AEE
VSSZZZ1MZ2R071252 SEZ7Z0A1429279
1 Fault Found:
16804 - Catalyst System; Bank 1
P0420 - 35-00 - Efficiency Below Threshold
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 1C0-907-37x-ABS.lbl
Part No: 1C0 907 379 J
Component: ABS FRONT MK60 0103
Coding: 0001025
Shop #: WSC 00001 001 00001
VCID: 31636460AB32456
No fault code found.
Part No: 1C0 909 605 A
Component: 1L AIRBAG VW51 0A 0004
Coding: 12620
Shop #: WSC 06441
VCID: 22419B2CAED4EEE
Address 17: Instruments Labels: 1M0-920-xx2-17.lbl
Part No: 1M0 920 802 A
Component: KOMBI+WEGFAHRSP VDO V02
Coding: 04106
Shop #: WSC 00000
VCID: 244D9D34B4C0E0E
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 06402
VCID: F0E52164B0B88CE
Address 46: Central Conv. Labels: 1C0-959-799.lbl
Part No: 1C0 959 799 E
Component: 2U Komfortgerát HLO 0003
Coding: 00067
Shop #: WSC 06402
VCID: 39735C4023428D6
Subsystem 1 - Part No: 1C1959801A
Component: 2U Tõrsteuer.FS KLO 0002
Subsystem 2 - Part No: 1C1959802A
Component: 2U Tõrsteuer.BF KLO 0002
1 Fault Found:
00912 - Window Regulator Switch; Front Left (E40)
27-10 - Implausible Signal - Intermittent
Va rog daca puteti sa imi spuneti ce inseamna aceste erori, mai ales prima P0420.
Am mai fost la un mecanic si mi-a zis ca e dusa sonda lambda nr.1 inainte de catalizator, am cumparat una universala de la bosch cu 4 fire dar cand am vrut sa o schimb am vazut ca cei de la magazin nu o comandasera bine caci a mea de pe masina era cu 5 fire si am dus-o inapoi pentru ca asa a zis mecanicul ca nu e buna ca imi trebuie cu 5 fire.
As avea nevoie de ajutorul vostru daca v-ati confruntat cu aceste probleme.
As vrea sa stiu totusi daca sonda cu 4 fire este buna sau nu. Imi trebuie neaparat cu 5 fire?
Va multumesc
Seat Leon 1M, 1.6, 16V, 105CP
BENZINA
Comunitate online pentru specialistii in constructii
http://www.arhitectisiproiectanti.ro
adragut
Re: Coduri de eroare date de VCDS
19 Dec 2012, 12:11
gamer555 scrie:
http://wiki.ross-tech.com/wiki/index.php/16804/P0420/001056
M-am uitat si eu aici dar credeam ca ati mai avut careva eroarea asta si imi dati un sfat de unde sa incep cautarea. (spartura, catalizator, sonda 1, sonda 2) adica ce ar fi mai frecvent.
Poate imi da si altcineva vreun sfat.
Multumesc
BENZINA
adragut
18 Iul 2016, 09:01
adragut scrie:
gamer555 scrie:
Multumesc
Rezolvat! Schimbat catalizator si toba cu racord flexibil.
BENZINA
18 Iul 2016, 18:56
Ce marca de catalizator ai montat si cat a costat?
LEON 1.4 16V Kit FR
adragut
18 Iul 2016, 19:14
1000 lei a fost catalizatorul. Nu mai stiu marca. Era oricum ceva italian.
BENZINA
