Lion SAM
Ibiza 6L ( Erori coduri VCDS ) Vag-Com Si OBD II CAN BUS
11 Sep 2012, 17:06
Subiectul I
Rog pe cei mai avizati in ale Vag-Com-ului sau a celor care cunosc cate ceva despre OBD 2 sa dea o mica privire pe ce erori am eu si daca a mai fost cineva in situatia mea si a rezolvat aceste erori sa imi spuneti si mie ce si cum ati facut.
Ms anticipat !
Tuesday,11,September,2012,17:18:54:63170
VCDS Version: Release 908.0
Data version: 20090830
Chassis Type: 6L - Seat Ibiza/Cordoba
Scan: 01 02 03 08 09 15 17 19 25 37 44 46 55 56
VIN: VSSZZZ6LZ7R145164 Mileage: 26430km/16422miles
Part No: 03E 906 023 D
Component: SIMOS91 1.2l 4V 9510
Revision: --H04--- Serial number: SEZ5Z0G0231575
Coding: 0000071
Shop #: WSC 06402 785 00200
No fault code found.
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 6R0-907-37x-ABS.lbl
Part No SW: 6Q0 907 379 AF HW: 6Q0 907 379 AF
Component: ABS 8.0 front H05 0002
Revision: 00000000 Serial number: 00000000000000
Coding: 0002115
Address 08: Auto HVAC Labels: 6Q0-820-045.lbl
Part No: 6L0 820 045 C
Component: Klimaanlage X00.8
2 Faults Found:
65535 - Internal Control Module Memory Error
00-00 - -
30-00 - Open or Short to Plus
Address 09: Cent. Elect. Labels: 6Qx-937-049-C.lbl
Part No: 6Q2 937 049 F
Component: 000A BN-SG. 2S36
Coding: 16396
Shop #: WSC 06402
1 Fault Found:
01336 - Data Bus for Comfort System
80-10 - Single-Wire Operation - Intermittent
Part No: 6Q0 909 601 F
Component: 02 AIRBAG VW5 0010
Coding: 12338
Shop #: WSC 06401
Address 17: Instruments Labels: 6L0-920-xx3-17.lbl
Part No: 6L0 920 803
Component: KOMBIINSTRUMENT AGD V03
Coding: 00105
Shop #: WSC 00000
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: 02QT GATEWAY CAN 2S36
Coding: 00014
Shop #: WSC 06402
1 Fault Found:
Address 25: Immobilizer Labels: Redir Fail!
Component: IMMOBILIZER AGD V03
Coding: 00105
Shop #: WSC 00000
VSSZZZ6LZ7R145164 SEZ5Z0G0231575
Address 44: Steering Assist Labels: 6Q0-423-156.lbl
Part No: 6Q0 423 156 AB
Component: LenkhilfeTRW V270
Coding: 10111
Shop #: WSC 06402
Address 46: Central Conv. Labels: 6Q0-959-433.lbl
Part No: 6Q0 959 433 E
Component: Komfortgerát 0002
Coding: 00018
Shop #: WSC 06402
Eroarea din adresa 08 a aparut dupa ce mi s-a ars scanerul la un radio sony care il aveam pe masina, adica nu mai puteam sa caut statiile radio, ulterior fiind inlocuit cu un blaupunkt.
Erorile de la 09 si 19 sunt asa de cand ma stiu :((.
Foarte important am cautat pe wiki ross tech, adica la vag com acasa si da am gasit raspunsurile lor la aste erori, dar eu intreb daca s-a mai intalnit cineva cu ele in viata de zi cu zi si cum le-a rezolvat ca nu prea stiu sa le iau pe ghicite :(.
Subiectul II
Acuma trecem la ce ma tot framanta pe mine de cand am cumparat vag-com-ul.
Cei mai specializati in OBD II stiu ca acesta interfata vorbeste in diferite limbaje, ca sa fac o analogie ( C, C++, Java, si html )
Acuma ce ma framanta pe mine este ca eu am urmatoarele fire la mufa OBD II a masinii 4,5,6,7 si 14,16
4,5 sunt de impamantare sau masa
6 si 14 sunt Can High si Can Low
7 este linia K
Pana aici totul este ok, dar cand am verificat azi cu unchiul meu aceste linii, 16 avea 12V ceea ce e super, 4 si 5 erau pe zero si cand am facut 4 cu 16 si 5 cu 16 am aprins un bec pe care il foloseam sa vedem daca are masa adica am facut contact intre + si -, iar becul era rezistenta, deci este OK super OK si aici.
Linia 7 linia limbajului KWP era ok avea in jur de 7 sau 10 V.
Dar aici e marea mea suparare liniile 6 si 14 erau moarte, acuma am o mica nelamurire cumva eu trebuie sa am limbaj CAN sau nu, sau cumva masinile vin din fabrica cu acelasi tip de cablaj si eu desi am 6 si 14 ele defapt sunt ca si moarte ???
Eu cand bag testerul pe masinutza la un prieten pe passat ii apare ca interfata vorbeste in CAN, dar la mine interfata vorbeste doar in KWP :(. KWP 2000 sau KWP 1280( nu stiu exact numarul )
Si cumva pentru ca aceste linii sunt moarte am acele erori in cadrul modulelor 09 si 19 ???
Pentru cei care au citit aceasta salata de varza le multumesc mult pentru rabdarea lor sper ca am fost clar si daca ma puteti indrepta catre o soluti ar fi super :D
Va multumesc anticipat !
Seat Ibiza 1.2 12v
al bundy
Re: Ibiza 6L ( Erori coduri VCDS ) Vag-Com Si OBD II CAN BUS
11 Sep 2012, 23:31
NU, masina ta nu suporta diagnoza pe CAN, doar pe K line.
Lion SAM
12 Sep 2012, 07:02
mersi mult al bundy, dar cu codurile de eroare ce fac sa fac ???
Seat Ibiza 1.2 12v
