nakano
HELP! Leon FR Error codes
19 Iun 2012, 12:44
Salutare, cine ma ajuta cu ceva info legate de err. de mai jos?
Multumesc anticipat, fac cinste , nu-i problema!
As merge la reprezentanta, dar sincer din proprie experienta cand vine vorba de electrica, tot ce fac este sa taie mufe.. In plus, nu pot reproduce eroarea si daca o sterg, apare peste 1-2-3zile.
Azi le-am sters, am inchis usile in toate felurile,dechis din telecomanda,trantit, etc etc. am mers cu masina puternic, curbe,linii de tramvai etc etc... am oprit, am scanat si ...nimic.
(mentionez ca "fizic" nu observ nici o defectiune.)
Sunt 4 erori, din care 3 cred ca sunt legate intre ele, iar a 4-a nu sunt sigur (banuiesc ceva legat de alarma? dar ..)
09-Cent. Elect. -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
62-Door,Rear Left -- Status: Sporadic communication error 1000
46-Central Conv. -- Status: Malfunction 0010
Address 09: Cent. Elect. Labels: 3C0-937-049.LBL
Part No SW: 3C0 937 049 E HW: 3C0 937 049 E
Component: Bordnetz-SG H37 1002
Coding: E38E0F2F00041000001D00000000000000017F075C
Shop #: WSC 06441
Part No: 1P0 955 119 A
Component: Wischer SE350 012 0403
Coding: 00056272
Shop #: WSC 06441
Part No: 1P0 955 559
Component: REGENLICHTSENSORH04 0090
Coding: 00137517
Shop #: WSC 06441
1 Fault Found:
01333 - Door Control Module; Rear Left (J388)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 166
Mileage: 57754 km
Time Indication: 0
Freeze Frame:
OFF
Voltage: 12.35 V
OFF
ON
OFF
OFF
Address 19: CAN Gateway Labels: 1K0-907-530.LBL
Part No SW: 1K0 907 530 K HW: 1K0 907 951
Component: J533__Gateway H12 0170
Coding: 7D3F03C007000202
Shop #: WSC 06441
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 166
Mileage: 57754 km
Time Indication: 0
Date: 2000.00.00
Time: 08:04:10
Address 46: Central Conv. Labels: 1K0-959-433-46.LBL
Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
Component: KSG PQ35 G2 020 0203
Coding: 998000005283CC7F0006050560084F86307C00
Shop #: WSC 06441
Part No: 1P0 951 171
Component: Innenraumueberw.010 4971
Coding: 00000000
Shop #: WSC 06441
Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Component: NGS n.mounted
1 Fault Found:
01135 - Interior Monitoring Sensors
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 164
Time Indication: 0
Re: HELP! Leon FR Error codes
19 Iun 2012, 13:57
ai spus ca ai 4 erori dar ai listat doar 3.
01333 - Door Control Module Rear Left (J388): Defective
Possible Causes
Fuse(s) faulty
Wiring and/or Connector(s) from/to Door Control Module Rear Left (J388) faulty
Possible Solutions
Check Fuse(s)
Check Wiring and/or Connector(s) from/to Door Control Module Rear Left (J388)
Check/Replace Door Control Module Rear Left (J388)
diferenta e ca la tine eroarea spune "intermitent" si nu "defective", deci probabil nu e de la sigurante. ramane sa verifici cablajul, si daca sunt ok, atunci buba tre sa fie in acel control module J388 din usa
01135 - Interior Monitoring Sensors: Open Circuit
Possible Causes
Wiring/Connector from/to Interior Monitoring Sensors faulty
Interior Monitoring Sensors not installed
Possible Solutions
Check/Repair Wiring/Connector from/to Interior Monitoring Sensors
See Measuring Blocks
Check Interior Monitoring Sensors Installation
si aici la tine eroarea spune intermitent, deci trebuie sa fie de vina un fir intrerupt, contacte, etc.
nu cred ca e simplu de diagnosticat unde e problema, trebuie un pic de rabdare. oricum, asteapta sa vezi ce spune si cosmin
boditza
19 Iun 2012, 14:00
Ultima cu interior monitoring sensor apare de cate ori suna alarma... cel putin la mine daca sterg erorile si suna alarma de 3 ori cand le citesc imi arata la frequency 3. De a 2-a nu stiu ce sa zic. Ti se deschide normal usa? Merg toate functiile de la ea?
nakano
19 Iun 2012, 14:28
Va multumesc frumos.
Deci, apar 4 erori dar ultima cu "62-Door,Rear Left -- Status: Sporadic communication error 1000" nu mai apare mai jos in log. (de aici doar 3 loguri detaliate)
Primele 3 sunt legate de usa stanga spate (corectati-ma daca gresec)
Ultima o sa testez putin mai incolo sa vad daca apare de la alarma (care este una simpla,nu volumetrica cum am mai avut la alt leon)
Am citit si eu info de la ross-tech, dar dupa cum spui si tu nu da "defective" ci "intermittent" deci este altceva + ca de la 11 azi am mai scanat de 2ori (blocat usa,inchis,armat,tot tacamul) si nimic.
Usa se inchide normal, se armeaza mereu (verific de fiecare data), atat din interior cat si din exterior. Nu vad nici o problema fizica. Ma gandesc ca daca eroare e sporadica, poate sa existe o intrerupere de cateva secunde,eroare apare iar apoi se remediaza si nu mai ai cum sa vezi nimic. (normal, eroarea nu dispare fara sa o sterg)
Teama este sa nu stea mai mult pe eroare vreodata si sa ramana usa deschisa....
Vroiam sa verific firele din mansonul usii, dar nu prea am reusit sa dau plasticul la oparte si cum nu am acces la manualul de service nu as vrea sa rup ceva ....
Alte idei? Multam'
nakano
19 Iun 2012, 16:29
Testa si faza cu alarma (lasat geamurile jos si armat) a inceput sa tiuie...dar dupa scanare ..no err.
nakano
26 Iun 2012, 10:21
Ramane in continuare numai eroare de mai jos.
Nu gasesc nimic sa nu mearga si nici nu-mi pot da seama de la ce ar putea fi. O sa merg si la Porsche, desi ...
Alte Idei?
Thx.
Shop #: WSC 06441
Coding: 00000000
Shop #: WSC 06441
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 164
Time Indication: 0
