luci&dana
VIP
Vand sistem audio 5.1 PIONEER
27 Ian 2012, 23:53
ImagineImagineImagineImagineImagineImagineImagine
Pozele nu sunt facute de mine, sunt gasite pe net. Sistemul este mult peste ce se gaseste in Romania la ora actuala. Are o fidelitate incredibila, multe setari. Este un model facut doar pentru Statele Unite.
Este achizitionat din Statele Unite de la reprezentanta Pioneer. Nu cred ca l-am folosit mai mult de 200 de ore din 2007 pana in prezent. A stat doar in cutii. Arata impecabil, nici o zgarietura, nici o eroare de citire la nici unul din cele 5 CD/DVD-uri.
Cateva specificatii:
DVD/CD Receiver XV-DV8
Speaker System S-DV8
Specifications
Amplifier section
Continuous Power Output (RMS):
Front, center, surround . . . . . 100 W per channel(1 kHz, 10 % T.H.D., 6Ω)
Subwoofer . . . . 100 W (100 Hz, 10 % T.H.D., 6Ω)
FM tuner section
Frequency range . . . . . . . . . . . . . . 87.5 – 108 MHz
Antenna . . . . . . . . . . . . . . . . . . . 75Ω, unbalanced
AM tuner section
Frequency range
With 9 kHz step . . . . . . . . . . 531 kHz to 1,602 kHz
With 10 kHz step . . . . . . . . . 530 kHz to 1,700 kHz
(Not applicable to the Saudi Arabian model)
Antenna . . . . . . . . . . . . . . . . . . . . . . Loop antenna
Miscellaneous
Power requirements . . . . . . AC 120-127/220-230/240 V (switchable), 50/60 Hz
Power consumption . . . . . . . . . . . . . . . . . . .180 W
Power consumption in standby. . . . . . . . . . 0.5 W
Dimensions . . . . .420 (W) x 126 (H) x 445 (D) mm
Weight . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9.8 kg
Speaker System
(Front speakers x2, surround speakers x2, center speaker x1, subwoofer x1)
Front speakers
Enclosure . . . . . . . . . . Closed-box bookshelf type(magnetically shielded)
System . . . . . . . . . . . . . . . . . . . . . . . 2-way system
Speakers
Woofer . . . . . . . . . . . . . . . . . . .10 cm cone type
Tweeter . . . . . . . . . . . . . . . . . 5.2 cm cone type
Nominal impedance . . . . . . . . . . . . . . . . . . . . .6Ω
Frequency range . . . . . . . . . . . . . 50 Hz to 20 kHz
Maximum Input Power . . . . . . . . . . . . . . . . 100 W
Dimensions . . . . 155 (W) x 364 (H) x 190 (D) mm
Weight . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .2.6 kg
Center speaker
System . . . . . . . . . . . . . . . . . 8.7 cm 1-way system
Speakers. . . . . . . . . . . . . . . . . . . 8.7 cm cone type
Frequency range . . . . . . . . . . . . . 65 Hz to 20 kHz
Dimensions . . . . . 350 (W) x 120 (H) x 75 (D) mm
Weight . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 kg
Surround speakers
Frequency range . . . . . . . . . . . . . 95 Hz to 20 kHz
Dimensions . . . . 155 (W) x 110 (H) x 110 (D) mm
Weight . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .0.8 kg
Subwoofer
Enclosure . . . . . . . . . . . . . . . Bass-reflex floor type
System . . . . . . . . . . . . . . . . . .16 cm 1-way system
Speaker. . . . . . . . . . . . . . . . . . . . .16 cm cone type
Frequency range . . . . . . . . . . . . . . .35 Hz to 2 kHz
Dimensions . . . . 190 (W) x 360 (H) x 327 (D) mm
Weight . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .5.0 kg
Accessories (Speaker system)
Speaker cables. . . . . . . . . . . . . . . . . . . . . . . . . . . .6
Non-skid pads . . . . . . . . . . . . . . . . . . . . . .2 sheets
Pretul lui a fost undeva la 800 de dolari. Eu cer pe el 1000 ron
Detalii aici pe site sau mail la luci_dana_2004@yahoo.com. Luci
Seat Ibiza 1.4 16V 86 CP
luci&dana
VIP
Re: Vand sistem audio 5.1 PIONEER
31 Ian 2012, 22:35
up!
luci&dana
VIP
02 Feb 2012, 10:25
sus :bom:
luci&dana
VIP
04 Feb 2012, 10:49
rezervat pentru cateva zile :yah
luci&dana
VIP
17 Iun 2012, 11:59
up!
